how to control dc motor by pwm????
Ai Lim
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Tue Apr 09, 2013 4:16 am     Reply with quote
i have a question~~~
now i am doing my project but my coding is very poor~~
i wanna ask that how to control dc motor by pwm?? and i need control my motor move forward, backward, turn left and turn right~~
i use PIC18F2331, 2 L293DD half bridge driver(because i need control 4 dc motors), crystal 20M, my dc motor is 3volt each~~~
hope someone can help or guide me solve the problem~~~~
SherpaDoug
PostPosted: Tue Apr 09, 2013 7:35 am     Reply with quote
Start out by studying the example programs ex_pwm.c and ex_power_pwm.c. Also read the PIC datasheet sections on the PWM capabilities of your chip.
asmboy
PostPosted: Tue Apr 09, 2013 8:29 am     Reply with quote
you should also determine if you need a PWM DC modulator ( with filter) - or if you can safely direct switch the motor. ( a circuitry question )
understand that direct switching , while very simple, can cause harmful levels of RFI /EMI to other electronics in your vicinity.
branko
Re: how to control dc motor by pwm????
PostPosted: Tue Apr 09, 2013 8:41 am     Reply with quote
Generate PWM and use a button to increment or decrement a variable from 0 to 255. Use this variable's value to set the duty cycle of PWM signal. If your MCU gives 5V o/p then you need to bring the PWM voltage to 3V before giving it to the motor.
Regards
Branko
