strange problem regarding internal EEPROM
syeda amna
PostPosted: Mon Apr 08, 2013 2:46 am     Reply with quote
I am facing a strange problem. I want to test the internal eeprom of the controller. I made a test program. When i entered a number which is less than 11 digits like 1233456 it works well. if the entered data is greater than 11 digits then the eeprom value changes. there is no command for writing eeprom.
example:
entered quantity=123456
chg=Null
entered quantity=01234567890123456789
chg=123456789
plzz help me. where is the problem?
#include <18F452.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,BROWNOUT
#use delay(clock=16M)
#include <string.h>
#include <input.c>
char chg=" ";
char pass[24] = {""};
chg=read_eeprom(0);
puts(chg);
get_string(pass, 24);
puts("\n");
puts(chg);
PostPosted: Mon Apr 08, 2013 3:52 am     Reply with quote
char chg=" ";
This line is wrong, you cannot assign a string to single character variable.
Because of weak type checking in the CCS compiler you are not warned, but this is an error in your program.
A string is an array of characters, terminated by a zero. So, the shortest string you can make consists of 1 character + a zero, total 2 bytes.
Try:
#include <18F452.h>
#include <string.h>
#include <input.c>
char chg[2];
chg[0]=read_eeprom(0);
chg[1]=0;    // Add string terminating zero
puts(chg);
puts("\n");
puts(chg);
while(1);    // loop forever. Prevent the processor from going to sleep and
             // not sending the last characters in the UART buffer.
Note that in this example the variable chg has changed from a 'char' to an 'array of char'. This is a huge difference to the compiler, the variable chg is not just a single byte in memory any more but has changed to a pointer, i.e. a variable holding an address to data stored somewhere else in memory.
