Use of PINS C6&C7 as output in PIC184550 + USB Enabled
younder
PostPosted: Sat Apr 06, 2013 4:05 pm     Reply with quote
Does anyone know if I can use the two mentioned pins(C6 and C7) in PIC18F4550 as output with USB function enabled? I have tested it with a single output_toggle function, but it did not work..... I know that C4 and C5 cannot be used as Input when USB active, but what about 6&7? Any help would be appreciated!
Hugo
Hugo Silva
PostPosted: Sat Apr 06, 2013 4:30 pm     Reply with quote
Post a little test program that shows this.
Example of a short, complete test program for 18F4550:
http://www.ccsinfo.com/forum/viewtopic.php?t=49056&start=14
Also post your CCS compiler version if you know it.
PostPosted: Sat Apr 06, 2013 7:21 pm     Reply with quote
...according to the datasheet, table 1-2, both C6 and C7 can be used for digital I/O but have ST not TTL buffers.
we'd have to see your code to figure out what you're doing wrong....
hth
jay
PostPosted: Sun Apr 07, 2013 4:27 am     Reply with quote
Obvious things would be either the UART is enabled, or SPI.
