16F1936 PWM CCP2 Half bridge P2B not working
nailuy
PostPosted: Sat Apr 06, 2013 3:13 pm     Reply with quote
Hy guys can tell me if someone have this problem?
I try to put output "RC0" in high level and is OK.
When I setup CCP2 in half bridge "RC0" or P2B is not working, when P2A is okay.
P1A, P1B, P2A, I have wave on the scope.
P2B, output is 0V on scope.
I put my code to help understand where is the problem:
in C program:
#include <16F1936_prog_v3.h>
#byte APFCON = 0x00
setup_adc(ADC_CLOCK_DIV_16);
setup_vref(VREF_ADC_4v096);
setup_timer_2(T2_DIV_BY_1,225,1);
setup_ccp1(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L|CCP_TIMER2);
setup_ccp2(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L|CCP_TIMER2);
setup_lcd(LCD_DISABLED);
setup_oscillator(OSC_16MHZ|OSC_TIMER1|OSC_PLL_OFF,0);
port_E_pullups(0x08);
for(;;){
set_pwm1_duty(75);
set_pwm2_duty(151);
and in H program:
#include <16F1936.h>
#device *=16
#device adc=10
#use delay(int=16M)
#FUSES INTRC_IO      //Internal RC Osc, no CLKOUT
#FUSES PROTECT       //Code protected from reads
#FUSES CPD           //Data EEPROM Code Protected
#FUSES WRT           //Program Memory Write Protected
#FUSES PLL_SW        //4X HW PLL disabled, 4X PLL enabled/disabled in software
#FUSES NOSTVREN      //Stack full/underflow will not cause reset
#FUSES NOLVP         //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOMCLR        //No MCLR
#FUSES NOPUT         //No Power Up Timer
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1,enable=PIN_A2)
PostPosted: Sat Apr 06, 2013 4:25 pm     Reply with quote
You are mixing together the constants for ordinary PWM and for
enhanced mode (Half Bridge). That is not correct.
#byte APFCON = 0x00
That's not how the #byte statement is used. Look it up in the CCS manual.
PostPosted: Sat Apr 06, 2013 4:28 pm     Reply with quote
also
you should add 'errors' to the use RS232(...options...).while you don't need it now....in future when you use serial communications, it keeps the hardware UART from 'locking up' due to errors.
hth
jay
PostPosted: Sat Apr 06, 2013 4:34 pm     Reply with quote
nailuy, please read this section of your previous thread which
had a problem with the #byte statement:
http://www.ccsinfo.com/forum/viewtopic.php?t=47381&start=9
nailuy
PostPosted: Mon Apr 08, 2013 12:03 pm     Reply with quote
Sorry for my late reply. I will back with update later.
Best regards.
nailuy
PostPosted: Mon Apr 08, 2013 1:56 pm     Reply with quote
I let enable only this line CCP2 and problem persists.
So problem isn't from here.
I don't know how to use hardware Uart.
so I make disabled this line.
I try to use APFCON like:
in the main.c, after void main
SET_APFCONS (0b00000000);
and in header file I put:
#define SET_APFCONS(value)   {#ASM            \
                             MOVLW  value    \
                             APFCON          \
                             #ENDASM}
and error is:"Expecting an opcode mnemonic APFCON"
Why? someone can make life easier?
Thanks.
notbad
PostPosted: Mon Apr 08, 2013 9:22 pm     Reply with quote
I had a similar P2B problem with another chip. Try output_drive(pin_C0); after setup_ccp2.
nailuy
PostPosted: Mon Apr 08, 2013 11:28 pm     Reply with quote
notbad
I will try this and I will come back with feedback.
Thank you.
PostPosted: Tue Apr 09, 2013 12:20 am     Reply with quote
Critical thing though is that he is ignoring the glaring error pointed out by PCM programmer. Even if the drive mode is set right, it is never going to work right. Currently it is like a person trying to make a car go by pushing both pedals (automatic) at once....
nailuy
PostPosted: Tue Apr 09, 2013 1:06 pm     Reply with quote
notbad
Feedback:
Your solution is good and works very well.
Thank you very much notbad.
Dear all how can I set this register APFCON?
I want to learn for the future.
Best regards.
PostPosted: Tue Apr 09, 2013 2:37 pm     Reply with quote
The easiest way is:
#byte APFCON=getenv("SFR:APFCON")
//Then just write it when you want
    APFCON=0b00000000;
//Choosing the value as needed
nailuy
PostPosted: Wed Apr 10, 2013 12:24 pm     Reply with quote
I'm sorry to respond, but does not work.
I'm begin to think it is a bug.
I think changing the subject with the word bug.
If you have any solution I'm happy to test your solution.
Thank you.
