PWM
amjad_alahdal
View user's profile Send private message Yahoo Messenger MSN Messenger
PWM
PostPosted: Wed Apr 03, 2013 11:21 am     Reply with quote
I need to use PWM1 and PWM2.
I got confused about how to set the Duty Cycle. Nevertheless, I need to set it to be 50%.
I will use those functions :
setup_ccp1(CCP_PWM);
set_pwm1_duty(value);
setup_ccp2(CCP_PWM);
set_pwm2_duty(value);
If I am not wrong. PWM1 and PWM2 referred to the PWM in the data sheet of my pic
asmboy
PostPosted: Wed Apr 03, 2013 11:37 am     Reply with quote
if using 10bit pwm must use int16 for value or L integers
8bit 'value' ok for 8 bit pwm resolution
amjad_alahdal
PostPosted: Wed Apr 03, 2013 11:50 am     Reply with quote
I'm using PIC 18F2455
amjad_alahdal
PostPosted: Wed Apr 03, 2013 12:01 pm     Reply with quote
I have written this code so far
      setup_timer_2(T2_DIV_BY_1, 127, 1);
But , I don't think this is how it works
PostPosted: Wed Apr 03, 2013 12:14 pm     Reply with quote
Try a simple program for one PWM channel:
#include <18F2455.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP, CPUDIV1
#use delay(clock=4M)
setup_timer_2(T2_DIV_BY_16, 125, 1);
set_pwm1_duty(63);    // 50% duty cycle
amjad_alahdal
PostPosted: Wed Apr 03, 2013 12:20 pm     Reply with quote
Ok, Thank you .
I also want to be sure that I used the right pins. and if it helps. I'm using DC motors
PIC 18F2455
C2 for PWM1
C1 For PWM2
trying now
amjad_alahdal
PostPosted: Wed Apr 03, 2013 12:26 pm     Reply with quote
Thank You so Much.
^_^
just as I wanted.
amjad_alahdal
PostPosted: Wed Apr 03, 2013 9:09 pm     Reply with quote
Ok thanks, but I have another question. How can I turn the PWM off and use the port as Digital output ???
PostPosted: Wed Apr 03, 2013 9:13 pm     Reply with quote
The program below runs the PWM on pin C2 for 2 seconds, then it
turns off the PWM. Pin C2 will be set as an output pin, and will put
out a logic low level (0v).
include <18F2455.h>
delay_ms(2000);
setup_ccp1(CCP_OFF);
amjad_alahdal
PostPosted: Wed Apr 03, 2013 10:58 pm     Reply with quote
PCM programmer...
I got confused about how to calculate the Duty. I used the CCS help and figured out the following :
1- when writing setup_ccp1(CCP_PWM)
Time = (1/clock) * 4 * 16 * (period+1)
In out case :
Time = 504 us.
That means the frequency = 1.984 kHz
So,
New frequency = 0.992 kHz which makes the time = 1.008ms
Then
Duty = Time / (16 * (1/clock))
= clock*time/16
= (16*10^6 * 1.008 * 10^-3)/16
= 1008
in the program
you set it 63
I don't know how that happened
PostPosted: Wed Apr 03, 2013 11:16 pm     Reply with quote
This post has many links which explain PWM in CCS (for 16F and 18F
PICs). See this link on PWM duty cycle:
http://www.ccsinfo.com/forum/viewtopic.php?t=45968&start=1
