How to pass stream name of RS232 to a function?
stoyanoff
PostPosted: Wed Apr 03, 2013 11:29 am     Reply with quote
Hi! I want to use 2 RS232 USART modules. So I set stream name for each one, but I don`t know how to pass the stream name to function, so I could use a single function for data transfer?
What is the datatype of stream? It`s not string!
I want to do this
void RS232Transmition(stream StreamName)
       if(kbhit(StreamName))
             incomeData=getc(StreamName);
Thanks!
PostPosted: Wed Apr 03, 2013 12:53 pm     Reply with quote
Short answer: You can't pass a CCS "stream" identifier as a parameter.
You will have to use "if" statements and check a variable that you
define to hold the desired stream. Then, based on the value of that
variable, your "if" statement will call the desired fputc or fprintf
statement, etc., and use the desired stream.
RF_Developer
PostPosted: Thu Apr 04, 2013 1:43 am     Reply with quote
Reason: because getc() and similar IO functions are dealt with at compile time not runtime, so the parameters must be known - fully resolved - at compile time. Therefore you can't pass a variable to them at runtime.
RF Developer
PostPosted: Thu Apr 04, 2013 7:20 am     Reply with quote
and of course 'behind' this is the core difference between writing code on the PIC, and something like a PC. On the latter you have hundreds of KB of 'OS' already loaded to do all these jobs. So simply changing which routine in the OS is called is simple. On the former, there is nothing outside your code, so the compiler has to generate the code to access a port when asked. Due to the lack of space, no more than is needed is loaded.....
