FAT.c init function is not working ...
Arjun
PostPosted: Tue Oct 12, 2010 5:08 am     Reply with quote
Below is my code structure please can anybody suggest what might be the problem.
I am using PIC18F67 and 2 GB SD card.
(I am able to read write to raw memory of SD).
step1:
#define MMCSD_PIN_SCL     PIN_D6
#define MMCSD_PIN_SDI     PIN_D5
#define MMCSD_PIN_SDO     PIN_D4
#define MMCSD_PIN_SELECT  PIN_D7
          //mmcsd.c file is included
step2:
#use spi(SPI2, MODE=0, BAUD=1000000, DI=MMCSD_PIN_SDI, DO=MMCSD_PIN_SDO, CLK=MMCSD_PIN_SCL, BITS=8, MSB_FIRST, IDLE=1, SAMPLE_RISE, stream=mmcsd_spi)//, FORCE_HW)
step3:
fat_init()        // from the file fat.c
After this step if I check my SD card in pc its asking for format. Every time I format then only I tried for coding.
I tried with mk_file(temp_buff) -->fatopen(temp_buff,wcmd,&fichier);-->fatclose(&fichier);
Please can anybody help this out Rolling Eyes
Arjun
PostPosted: Thu Oct 14, 2010 8:32 am     Reply with quote
can anybody know the solution.....
Crying or Very sad
Is anybody there who can confirm me that they are able to create a file read/write in SD card using fat32 lib files.
andrewg
PostPosted: Fri Oct 15, 2010 2:03 am     Reply with quote
I think your #use spi code is wrong. This is what I have in my mmcsd.c:
#use spi(MASTER,CLK=MMCSD_PIN_SCL, DO=MMCSD_PIN_SDO, DI=MMCSD_PIN_SDI, BITS=8, MODE=3, STREAM=MMCSD_SPI, FORCE_HW)
The important differences are mode 3, no baud, no idle, and no sample_rise.
Also, make sure the card is formatted using the same FAT type (16 or 32) as the code is compiled for.
Andrew
Arjun
PostPosted: Mon Oct 18, 2010 12:31 am     Reply with quote
Thanks Andrew for help... Idea
For FORCE_HW its giving error.
I tested my code once I use MY_FILE function and then if I try to see my card using card reader in PC, its asking for format. If I see my card memory using property its showing 0 bytes used. The same thing if I try to see SD memory using some HEX editor. I can see my file name in the starting location in SD card (Any file name which I try to create using MY_FILE function).
Can anybody help me out ....
andrewg
PostPosted: Mon Oct 18, 2010 2:26 am     Reply with quote
You say you're using an 18F67....what? Also, what version of the compiler are you using? You probably need a very recent one to support SPI2.
Andrew
Arjun
PostPosted: Mon Oct 18, 2010 3:02 am     Reply with quote
Thanks Andrew ,
am using PIC18F67 and 2 GB kingstone SD card.
CCS is new ver ie CCS 4.1,i am able to see raw memory in which i can notice my file name in there. Sad
waiting for ur inputs....
andrewg
PostPosted: Mon Oct 18, 2010 7:28 am     Reply with quote
If you're using the mmcsd.c and fat.c library files provided by CCS, then you should read my two threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=43417
http://www.ccsinfo.com/forum/viewtopic.php?t=43402
The first addresses a bug in cluster chaining and the second adds MBR support.
Andrew
andrewg
PostPosted: Mon Oct 18, 2010 7:33 am     Reply with quote
I forgot to mention, in future, please be more precise, otherwise you end up wasting everyone's time. There is no such device as a 18F67, there are 10 devices that start with that designation and for future questions it might be important to know exactly which PIC you're using. Same for the CCS version. There are three digits after the decimal place, and they all can be important. eg, 4.112, or whatever.
Andrew
Arjun
PostPosted: Mon Oct 18, 2010 12:02 pm     Reply with quote
Thanks Andrew , Cool
Just want to tell you, you really helped me a lot and its working fine.
Thanks a lot.
Laughing
martind1983
PostPosted: Wed Apr 03, 2013 1:55 am     Reply with quote
Andrewg I read my card also in MODE=0 so I don't know why do you always suggest people to use MODE=3?
PostPosted: Wed Apr 03, 2013 2:29 am     Reply with quote
Have a look at the simplified SPI timing diagrams:
<mfb.nopdesign.sk/datasheet/cat_d/MMC/spitiming.pdf>
Notice where the clock line sits between bytes (high). Realise that this also means the pull up resistors are not wasting power being driven when data is not being sent. What mode numbers give this?. (not 0.....).
martind1983
Re: FAT.c init function is not working ...
PostPosted: Wed Apr 03, 2013 11:49 pm     Reply with quote
step1:
step2:
step3:
I seen the problem might also be, that in directive #USE SPI you use both SPI2 option and optional pins for software SPI. If you use SPI2 option it automatically switches pins assigned with SPI2 hardware so you cannot set your own election. And I am not sure, but when you use #SPI_HARDWARE option the result is the same. Compiler automatically build code to set pins associate with hardware SPI. I can't tell you for 100%, because I have never tried this combination.
