define input
vortexe90
define input
PostPosted: Thu Mar 28, 2013 6:22 am     Reply with quote
hi guys, I have a problem when I defined a 'Pin' of the microcontroller as input.
Example:
#include <16F877A.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#define UP input(PIN_D2);
     if (!UP)
     {output_low(PIN_B4); }
Error when i compile:
Expecting a close paren
A numeric expression must appear here
I use CCS compiler v4.130
PostPosted: Thu Mar 28, 2013 6:32 am     Reply with quote
I see
3 {
and
2 }
so the error message seems correct ..
hth
jay
vortexe90
PostPosted: Thu Mar 28, 2013 7:04 am     Reply with quote
I corrected the accolade but I still get the error
#device adc=16
if (!UP) //-------------------> I corrected this accolade but I still get the error here
{output_low(PIN_B4);}
jeremiah
PostPosted: Thu Mar 28, 2013 7:31 am     Reply with quote
Take a look at your #define. You did it incorrectly. It replaces UP with everything after it.
milan.rajik2013
PostPosted: Thu Mar 28, 2013 7:53 am     Reply with quote
Use #define UP PIN_D2;
If PIN_D2 is a switch then you have to use debounce delay otherwise your code will not work.
if(UP == 1) {
       delay_ms(50);
       if(UP == 1) {
             PIN_D4 = ~PIN_D4;
Regards
Milan
Last edited by milan.rajik2013 on Thu Mar 28, 2013 7:58 am; edited 1 time in total
PostPosted: Thu Mar 28, 2013 7:57 am     Reply with quote
As a 'what to look for'. Jeremiah is giving the right answer.
'Defines' in C are text replacement macros. Exactly what is typed in the second part replaces what is typed in the first.
Take what is on your define line, as the replacement part, and type it in yourself where you use this. Does it look right?.
