Implement 2 Ip addresses in TCP/IP stack
Manel28
PostPosted: Tue Mar 26, 2013 3:41 am     Reply with quote
Hi there,
does anybody know how to modify the TCP/IP stack in order to have 2 differenet IP addresses. I want my PIC+ ENC28J60 to listen to all incoming packets to 2 different IP interfaces.
Thanks for the help
FvM
PostPosted: Tue Mar 26, 2013 5:46 am     Reply with quote
As far as I see, multihoming requires several features that are not provided by the Microchip TCP stack. The Beta V6.0 has support for multiple network interfaces, you'll need to port it to CCS.
PostPosted: Tue Mar 26, 2013 5:51 am     Reply with quote
I'm not sure it is easy with that Ethernet chip either. The automatic filters don't support two addresses (except things like the broadcast address), so you'd have to effectively 'manually check' the packets.
There are later Ethernet chips with support for this.
Manel28
PostPosted: Tue Mar 26, 2013 6:15 am     Reply with quote
Thanks for the info Smile
asmallri
PostPosted: Tue Mar 26, 2013 10:23 am     Reply with quote
These issues are solvable. Only one physical interface is being used and the low level NIC driver is not concerned about IP addresses so it does not prevent packets from being processed by the upper layer IP stack (which you can modify).
This leaves the issue of MAC addresses. If the two IP addresses are in different subnets then they may be able to share the same MAC address. It will not impact the upstream switch or router. You could use multiple MAC addresses but to do this you will either need to configure the Ethernet controller to accept all destination MAC addresses (not very good) or you need to configure and enable the MAC hash table.
Regards, Andrew
FvM
PostPosted: Wed Mar 27, 2013 12:40 am     Reply with quote
I presume that multiple IP addresses will be bound to the same mac address. This can work with any network chip.
P.S.: I see, Andrew already commented the point.
PostPosted: Wed Mar 27, 2013 5:52 am     Reply with quote
I must admit when I've done multi-homing, I've wanted multiple Mac addresses.
Have always just used a lot more 'grunt' than the PIC. When you look at what you can get a matchbox PC, running Linux for, this sort of job is the an absolute doddle. Especially going with a USB SD based machine...
