Example of UART needed
jayanthd
PostPosted: Thu Mar 21, 2013 10:14 am     Reply with quote
Hello!
I have written a adc code shown here http://www.ccsinfo.com/forum/viewtopic.php?p=173480#173480
I want to sent the data serially through UART. I have done a lot of PIC projects using Hi Tech C, Cxx, XC, mikroE, and many other Compilers but I am new to CCS C Compiler.
Can somebody provide an example CCS C code for UART communication?
I just need to send my adc value through UART. I am using PIC16F877 at 20 MHz.
PostPosted: Thu Mar 21, 2013 11:04 am     Reply with quote
Put in a #use rs232() statement, the use printf() and send it. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=34386&start=1
If you have any questions about #use rs232() or printf(), then download
the CCS manual and read it:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
jayanthd
PostPosted: Thu Mar 21, 2013 11:28 am     Reply with quote
Where is the UART code? It shows only #use line which is for UART config.
How to use printf for UART. I use both LCD and UART. does using printf("UART"); prints data on UART terminal?
Edit: I got it working on Proteus and real hardware.
http://www.pixhost.org/show/3158/16383436_uart1.jpg
PostPosted: Thu Mar 21, 2013 11:42 am     Reply with quote
I'm glad you got it working, but you ignored my last statement, which
gave you a resource to read (the link to CCS manual) which would
answer all your questions.
PostPosted: Thu Mar 21, 2013 12:10 pm     Reply with quote
1) get RID of Proteus. At the very least NEVER,EVER think that Proteus is working 'right'...it is full of bigs, errors, faulty DRCs.if I had a 41 for every 'P' question...I'd be a millionaire, honestly.
2) read some of the hundred+ sample 'examples' that CCS supplies in the 'EXAMPLES' folder.99.9% of what 99.9% of the questions asked here can be answered by reading those examples.
3) 'odd' stuff....read the CCS compiler help files(pressing F11 opens it).
4) start with known code, edit,test,try again.build upon what you know works!
everyone here is willing to help,but not do your homework.
hth
jay
