syeda amna
Problem in comparing two strings Strcmp() |
Posted: Mon Mar 18, 2013 4:09 am |
why the code does not compare the two strings correctly??
#include <18F452.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,BROWNOUT
#use delay(clock=16M)
#include <string.h>
int8 i=0;
int8 x,y;
char password[2];
char line[80] = {"0123456789/0123456789"}; //sample string
char sep[] = {"/"};
char *data;
//=============Use strtok() function to to match/change password========//
data = strtok(line, sep); //It separates this "/"
while (data!=NULL)
password[i++]=data;
data = strtok(0, sep);
for(x=0;x<2;x++){
puts(password[x]);
y = strcmp (password[0] , password[1]) ;
if ( y == 0 )
puts("correct");
puts("incorrect");
Mike Walne
Posted: Mon Mar 18, 2013 4:49 am |
Try printing out the two passwords to see what you are actually comparing.
OR debug to examine RAM contents.
Mike |
syeda amna
Posted: Mon Mar 18, 2013 5:38 am |
they are same "0123456789". I use putc to see the contents. But it gives Incorrect . why? the same program works in standard C. |
jeremiah
Posted: Mon Mar 18, 2013 6:50 am |
Don't launch new threads asking the same question.
The version I posted in your previous thread, works.
If it doesn't for you, then the question 'compiler version' applies.
syeda amna
Posted: Mon Mar 18, 2013 6:57 am |
Sorry for posting new thread. I changed the program a little bit. Just because strcmp() doesn't work. this command still does not give the correct answer. I The same code is working in standard C. |
Mike Walne
Posted: Mon Mar 18, 2013 7:16 am |
Sorry. I didn't read your code carefully enough first time round.
I have just tried your code on a PIC18F458 (Just happened to be in my PICDEM 2 PLUS board).
I did it by cut and paste.
I can confirm the code works as expected.
Prints "correct" as is.
Prints "incorrect" when two halves of line[80] are not same.
Mike |
Posted: Mon Mar 18, 2013 8:03 am |
I have a 'nasty suspicion', we may be dealing with one of the 'ripped off' early V4 versions, where some things like this did have problems.....
FvM
Posted: Mon Mar 18, 2013 8:27 am |
char password[2]; means you can either store two characters, or a string comprised of one character and a terminating null.
strcmp compares strings, not characters, thus this function call makes no sense at all:
strcmp (password[0] , password[1]); |
syeda amna
Posted: Wed Mar 20, 2013 2:15 am |
Thanks FvM for mentioning the mistake.
Quote: | char password[2]; means you can either store two characters, or a string comprised of one character and a terminating null. |
Now i declare it as char *password[2];
Now the program is working well with the sample string.
Another problem arises
When i use gets() function (for inputting the string instead of the sample string), it is not working. the same program is working in standard C. plzzz help.
#include <18F452.h>
#include <string.h>
int8 i=0;
int8 x,y;
char *password[2];
char sep[] = {"/"};
char *data;
char pass[30] = {""};
//========Inputting String from User Separated by "/" =======//
gets(pass);
//=====Use strtok() function to to match/change password=======//
data = strtok(pass, sep); //It separates this "/"
while (data!=NULL)
password[i++]=data;
data = strtok(NULL, sep);
for(x=0;x<2;++x){
puts(password[x]);
if ( y == 0 )
puts("correct");
puts("incorrect");
Posted: Wed Mar 20, 2013 2:38 am |
Classic problem here is what you are using to send the string at the PC end.
Look carefully at what it is setup to send when you type 'return'.
Will your string then match?.
syeda amna
Posted: Wed Mar 20, 2013 3:02 am |
no effect ![Confused](images/smiles/icon_confused.gif) |
Posted: Wed Mar 20, 2013 3:45 am |
What do you mean 'no effect'. Have you actually looked at what it sends?....
Most terminal programs send either LF on it's own (which is not character 13), or CR/LF.
If the first case you won't get the CR you want, in the second, you will get an _extra_ LF in the string, which will mean they won't match....
Use get_string in input.c, instead of gets (better anyway since you can specify the maximum line length). Edit it's penultimate line to:
} while(c!=13 && c!=10);
set it so it won't overrun your string buffer (remember to allow for the space needed for the terminator), and make sure your terminal program is set to send just LF.
Think. |
syeda amna
Posted: Thu Mar 21, 2013 5:06 am |
Finally solved. the code is working with get_string().
thanks ttelmah and everybody. |
