Can't make pwm
khaledki7
Can't make pwm
PostPosted: Tue Mar 12, 2013 1:56 pm     Reply with quote
#include <18F452.h>
#use delay(clock=25000000)
#INT_TIMER1                        // This function is called every time
void clock_isr() {                 // timer 1 overflows (65535->0), which is
output_toggle(PIN_B3);
void main() {
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
   set_timer1(0);
     // output_high(PIN_B3);
   while(TRUE);
Mike Walne
PostPosted: Tue Mar 12, 2013 5:46 pm     Reply with quote
I don't understand the question.
Are you wanting to:-
1) Create a PWM output using timer1?
OR
2) Create a PWM output using the built in hardware version?
Mike
PostPosted: Tue Mar 12, 2013 7:49 pm     Reply with quote
PWM=Pulse Width Modulation.
Gives an approximate square wave with fixed 50% duty,
with no way to actually MODULATE it in your program.
At best it is a jittery square wave generator and nothing more.
PostPosted: Tue Mar 12, 2013 11:09 pm     Reply with quote
I tested your program in hardware, with CCS compiler vs. 4.141. I don't
have a 25 MHz external oscillator, so I used a 20 MHz crystal. It works.
I see a squarewave signal on Pin B3, with a frequency of about 9.5 Hz.
The signal goes from 0v to 5v. I can see it on my oscilloscope.
khaledki7
PostPosted: Wed Mar 13, 2013 1:39 am     Reply with quote
hi I want to make a 50HZ pulse but I can't make it
pleas help and thanks for reply
PostPosted: Wed Mar 13, 2013 1:59 am     Reply with quote
If you are working on a "hobby servo" project, which I think you are,
because of the 50 Hz frequency, then you should tell us in the first post.
Just say "I need help to make a program to drive a hobby servo".
Here is a demo program that shows how to use the CCS servos.c file:
http://www.ccsinfo.com/forum/viewtopic.php?t=34560&start=22
There are many examples of programs to drive servos in the forum
archives. Examples:
http://www.ccsinfo.com/forum/viewtopic.php?t=47510
http://www.ccsinfo.com/forum/viewtopic.php?t=44328
khaledki7
PostPosted: Wed Mar 13, 2013 6:19 am     Reply with quote
hi thanks for your help and i make this code but the servo didn't work. Any answers?
#include <18F452.H>
#device adc=8
#define LEFT_SERVO_PIN   PIN_B0
#define RIGHT_SERVO_PIN  PIN_B1
//#define LONG_TIME       0.0150      // Longest pulse width high time
#include <servos.c>
int j;
j=0;
init_servos();
//for (j=0;j<=4;++j)
//      set_servo(LEFT,  FORWARD,  j);  // Go forward
//      delay_ms(2000);
     // set_servo(LEFT, BACKWARD, 3);  // Go reverse
 set_servo(LEFT,  FORWARD,  4);
Mike Walne
PostPosted: Wed Mar 13, 2013 7:57 am     Reply with quote
What does not work?
In no particular order:-
1) Do you know that your servo is good?
2) Are there pulses appearing from the PIC pins?
3) Have you got servos which are compatible with the CCS servo drivers?
4) Have you checked, and double checked, your wiring?
5) Have you checked for accidental S/C and O/C?
6) Will your PIC run LED flasher code at the correct speed?
Mike
PostPosted: Wed Mar 13, 2013 8:08 am     Reply with quote
S/C = Short Circuit
O/C = Open Circuit
just in case anyone else is scratching their heads.....
jay
Mike Walne
PostPosted: Wed Mar 13, 2013 9:12 am     Reply with quote
When you get as many S/Cs and O/Cs as I do, it's a pain to write out in full every time.
Mike
PostPosted: Wed Mar 13, 2013 2:18 pm     Reply with quote
Don't call set_servo() continuously in a high-speed while() loop.
Just call it once, and it will work. See the example below:
#include <18F452.H>
#use delay(clock=4M)
#include <servos.c>
init_servos();
