rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
Bootloader doesn't work *Solved* |
Posted: Tue Mar 12, 2013 1:33 pm |
I used the example code: ex_bootloader and modified it to a desired chip and application settings. Here is the code:
#include <16F873A.h>
#use delay(clock=16M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#define _bootloader
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+1,LOADER_END+10
void application(void) {
while(TRUE);
#org 0x20,0x3F
void main(void) {
if(!input(PIN_B5))
load_program();
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
1. Is there something wrong with the bootloader code?
In the example code is written: Use an RS232 link and the SIOW.EXE program to load a new HEX file into the target chip.
2. How to load the hex file into SIOW.EXE? There is no browse or load hex file or something like that.
Here is the code I want to send via SIOW.EXE:
char c;
while (true)
c = getc();
putc(c);
3. Are these two codes correct and am I at the right direction with creating of a Bootloader project?
I know there is a lot of information about PICs and bootloaders in the Google searches but I am using CCS compiler and CCS firmware thats why I am inquiring you guys.
If you still think I am lazy, just don't answer me plz!
Thank you! _________________ A person who never made a mistake never tried anything new.
Joined: 01 Jul 2010 Posts: 9165 Location: Greensville,Ontario
Posted: Tue Mar 12, 2013 1:41 pm |
re: #1, #3...
Have you got the CCS supplied examples working yet ???
re: 2)
SIOW will download the program_name.HEX file, NOT the program_name.C file. You MUST download the HEX file (the compiled code) as a PIC only 'understands' machine code.
Within SIOW, go to 'file' menu, select 'download', choose the file you want to send to PIC......
Kinda simple, really even for a 6decade, preDOS guy like me. |
rikotech8
Posted: Tue Mar 12, 2013 1:57 pm |
temtronic I don't know so good English to thank you!
Man you are Genius.
Everything has been so simple. Both of my codes works perfectly well. I haven't change anything to my codes.
Thank you again temtronic! _________________ A person who never made a mistake never tried anything new. |
