Error In I2C Communications Between PICs
Geps
PostPosted: Sun Mar 10, 2013 10:02 am     Reply with quote
I'm setting up an I2C communication method between a single 18F46K22 and a single 12F1840. I have the following code compiled under 4.125 running on the 12F1840:
#include <12F1840.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP, NOMCLR
#USE delay(internal=32MHz)
#zero_ram
// ------------------------DEBUG-MODE-ACTIVATION----------------------------- //
//#define DEBUGMODE
   #define BUFFER_ADDRESS 0x12
// ----------------------------HARDWARE-SETUP-------------------------------- //
#use RS232 (stream = DEBUG_SERIAL, baud=115200, xmit=PIN_A4, rcv=PIN_A5, ERRORS)
#use i2c(SLAVE, SDA=PIN_A2, SCL=PIN_A1, address=BUFFER_ADDRESS)
int8 CommandByte = 0x00;
#INT_SSP
void int_ssp_isr() {
int8 State = 0x00;
State = i2c_isr_state();
  if((State == 0 ) || (State== 0x80)) {
    i2c_read();
  else if(State < 0x80) {
   CommandByte = i2c_read(0);
  else if(State > 0x80) {
      i2c_write(0x00);
    enable_interrupts(INT_SSP);
while(TRUE){
fprintf(DEBUG_SERIAL, "Running:%X", CommandByte);
delay_ms(10);
I'm finding that regardless of what value I set in the i2c_write parameter to I consistently get 0x26 back.
When the master starts up before the slave I see 0xFFs, the slave has then started it switches to 0x26 so I'm confident it's not the master transmitting the value.
As I can't see a 0x26 anywhere in my code, can someone please explain the possible source for it?
Cheers,
Geps
PostPosted: Sun Mar 10, 2013 12:40 pm     Reply with quote
Since posting I've been trying to enable the hardware UART buffer and found an old post by PCM Programmer in this thread that suggests the support for this chip is flawed:
http://www.ccsinfo.com/forum/viewtopic.php?t=47249&postdays=0&postorder=asc&start=0
So for now I'll put it down to compiler issues if nobody has anything...?
stinky
PostPosted: Sun Mar 10, 2013 8:58 pm     Reply with quote
Shot in the dark here.
Your #USE statement:
Is that actually setting it up for 32MHz operation from the internal oscillator? I haven't used that chip but I thought it had something to do with setting it at 8Mhz and then enabling the 4XPLL.
Again, just a guess.
stinky
PostPosted: Sun Mar 10, 2013 11:40 pm     Reply with quote
No I think I'm wrong there.
Just looked at the compiled code.
Sorry
