Trouble getting PIC10f320 to run
ralpok
PostPosted: Sat Feb 09, 2013 12:57 pm     Reply with quote
I have a project I have started with the PIC10f320 micro controller. I want to just get a simple program running toggling PIN4 (GP2) on the device. As far as I can tell I am unable to even get this running and since this chip/compiler doesn't support debugging I am a bit lost. The program I have tried to run is:
I am running Win 7:
CCS Studio: PCWHD 4.134
#case
#include <10f320.h>
#device ADC=10
#fuses NOWDT
#use delay (internal=8000000)
   int8 velocity[10];
   int16 avgVelocity = 0;
   int ndx = 0;
   delay_ms(2000);
   set_tris_a(0x00);
   output_high(PIN_A2);
   while (1)
      output_toggle(PIN_A2);
      delay_ms(10);
Any thoughts people have on why I can't get the pin to toggle would be appreciated. I even disconnected it from anything else on my circuit board to make sure something wasn't holding it low.
PostPosted: Sat Feb 09, 2013 1:42 pm     Reply with quote
I don't use that PIC but ...
1) check to see what other peripherals can also use that pin. Typically the
ADC will default to being 'attached'. Also comparitors, UART, MSSP,etc.
2) What pullup resistor are you using? Some PIC pins are open drain and need a load..
3) Is that pin configurable as an OUTPUT ? While most are, some aren't all depends on the PIC
Check the datasheet it'll soon tell you the defaults for the I/O pins as well as functionality(I/O, I only,O only)
Also...be sure to have 'release' selected as the build configuration within MPLAB.
hth
jay
PostPosted: Sat Feb 09, 2013 3:52 pm     Reply with quote
On the 10F320, A0 to 2, wake up as analog. This overrides port I/O. You need to turn this off.
From the data sheet:
"Note: The ANSELA bits default to the Analog
mode after Reset. To use any pins as
digital general purpose or peripheral
inputs, the corresponding ANSEL bits
must be initialized to ‘0’ by user software."
ralpok
PostPosted: Tue Feb 19, 2013 10:47 am     Reply with quote
Thank you guys for all your help. Your advice and input got me heading in the correct direction and I was able to pretty quickly get this up and running. In the end I had to manually set the PORTA, LATA, ANSELA, and TRISA registers in order to get it working. I followed the assembly that was in the datasheet and this seems to work. I can probably do this using the CCS Libraries in some way but I am not sure how. In case anybody else is interested I will post my working code.
#case
#include <10f320.h>
#device ADC=10
#fuses NOWDT, INTRC
#use standard_io(A)
#byte PORTA = 0x05
#byte LATA = 0x07
#byte ANSELA = 0x08
#byte TRISA = 0x06
   int8 velocity[10];
   int ndx = 0;
   delay_ms(2000);
   PORTA = 0x00;
   LATA = 0x00;
   ANSELA = 0x00;
   TRISA = 0x00;
   while (1)
      output_low(PIN_A2);
      delay_ms(10);
      delay_ms(10);
PostPosted: Tue Feb 19, 2013 1:16 pm     Reply with quote
1) TRIS is set for you.
2) PORT/LAT registers are set for you.
3) setup_adc_ports.....
stinky
PostPosted: Wed Mar 06, 2013 10:37 pm     Reply with quote
I'd suspect that the reason your later code works and the first code didn't is the following.
original code:
#fuses NOWDT
updated code:
#fuses NOWDT, INTRC
Without "INTRC" specified it defaulted to looking for an external clock. If you didn't have that clock, no instructions were executed at run time. And no pin was toggled.
PostPosted: Wed Mar 06, 2013 11:09 pm     Reply with quote
Look at the Fuses in the .LST file for his first program:
Configuration Fuses:
Word 1: 3EC6 INTRC BROWNOUT NOWDT PUT MCLR NOPROTECT NOLVP LPBOR BORV19 NOWRT NODEBUG
When the compiler sees the "internal" keyword in the #use delay()
statement, it enables the INTRC fuse:
#case
#include <10f320.h>
#device ADC=10
#fuses NOWDT
However, I personally prefer to specify it in the #fuses statement and
not in the #use delay().
