rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
Bootloader? What is that for?!! |
Posted: Sat Mar 02, 2013 9:06 am |
Hello guys!
I am not a professional ccs programmer that's why I often ask such a type of questions.
What is a bootloader and why we use it?
Thank you for helping me understand controllers better! _________________ A person who never made a mistake never tried anything new. |
Gabriel
Posted: Sat Mar 02, 2013 9:16 am |
Brief explanation:
its a small program that you burn once with a normal programmer like a Pickit ...
later when you want to upload your code you send it to the pic using the serial port...
the small program you burned, takes the serial data and writes it to your code space...
basically eliminates the need for a programmer.
this allows for firmware updates without a programmer.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Sat Mar 02, 2013 3:32 pm |
Just to emphasize it a bit more:
A bootloader is a program on your chip that allows someone in the field (customer or service person) to update the firmware without special programming hardware. Often the user then connects the serial port to his PC for uploading the new firmware software. USB and ethernet bootloaders also exist.
When your chip is only ever going to be programmed in the factory or your lab, then you don't need a bootloader. A bootloader is slower than programming with your special programming hardware (ICD, PicKit, etc) and it takes up about 1k of ROM. |
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Posted: Sun Mar 03, 2013 2:27 am |
A bootloader can be used to replace all or just part of the space you have allocated for the application program. Depending on the implementation. a bootloader can modify as little as a single byte of program memory. This enables a bootloader to be used to update tables maintained in program memory (for example an emulated EEPROM) without updating the application itself. _________________ Regards, Andrew
