Serial Programming
vishnuvarkala
Serial Programming
PostPosted: Sat Mar 02, 2013 7:31 pm     Reply with quote
Can any one tell me how to program an 18f452 using a serial boot loader. Is their any boot loader available for programming this chip through the D+ and D- pins. In other words, can I program this chip directly through the usb port of my PC, without using a programmer!!! Smile
bkamen
Re: Serial Programming
PostPosted: Sat Mar 02, 2013 8:03 pm     Reply with quote
Look at this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=49989
So, yes, you can program a PIC without a programmer ONCE the bootloader is installed. (obviously PIC's that have little flash space may not be able to hold the bootloader. Some PIC's are not cut out for bootloaders.)
Keep in mind though that the bootloader has special needs because it should always stay in FLASH and should never be allowed to erase/damage itself.
So -- from here, go and look at the bootloader example that's supplied with CCS PIC-C.
Then you can apply that to the USB port (which is possible, I've modified the Microchip free USB bootloader for a client's needs). USB is needs just like RS232 might -- so keep that in mind. But definitely possible.
If you still have questions, come on back and let us know what they are.
-Ben
vishnuvarkala
Serial Programming
PostPosted: Mon Mar 04, 2013 4:44 pm     Reply with quote
I read so many articles regarding the serial programmer , using a bootloader and MAX232 IC .The problem is ,most of the laptops and PCs now don't have a serial port. So this are my requirements
->direct connection from the D+ and D- of the usb port to the D+ and D- of the 18fxxx chip.
->A bootloader for directly reading the data coming through D+ and D-
->A software for sending the .HEX file through the usb port. The software should be able to detect the chip when directly connected to the usb port.
bkamen
PostPosted: Mon Mar 04, 2013 4:57 pm     Reply with quote
That's easily solved with:
1) An FTDI232 chip.
2) A USB-Serial Dongle
but -- wanting a USB only is fine. You can do USB bootloaders.
Microchip even gives one away (but it's written to compile with Microchip's compilers. Not that it couldn't be re-written to compile with CCS.. but..)
USB Bootloaders are out there. I just don't think CCS has one with their compiler. (Someone can correct me if I'm wrong)
Also, did you search the code library here at all?
http://www.ccsinfo.com/forum/viewtopic.php?t=21396
http://www.ccsinfo.com/forum/viewtopic.php?t=36721
-Ben
