aruna1
extern and union |
Posted: Wed Feb 27, 2013 6:15 am |
hi guys;
I'm trying to define a union in main.c file and use it on another c file in Same project using extern key word,
but compiler fail to compile.
main.c
Code: | union rcv{
char chr_array[8];
unsigned int16 int16_array[4];
unsigned int32 int32_array[2];
interruptc.c
Compiler cannot compile it and gives me following error:
error33"E:\Interrupts.c" Line7(23,31):Expecting a {
Can someone please tell me how to use union with extern keyword properly.
My pic is 16F628A.
compiler version is 4.084
thanks |
Posted: Wed Feb 27, 2013 6:27 am |
Problem is that you haven't got a variable called rcv, just a union declaration for it. Extern applies to a variable declaration. You need a variable name in the extern declaration. I'd suggest typedefing the union declaration, and using this to declare the variable.
aruna1
Posted: Wed Feb 27, 2013 6:37 am |
Ttelmah wrote: | Problem is that you haven't got a variable called rcv, just a union declaration for it. Extern applies to a variable declaration. You need a variable name in the extern declaration. I'd suggest typedefing the union declaration, and using this to declare the variable.
Can you please show me how to do it?
This is the first time I'm using union or typedef.
Thanks |
Posted: Wed Feb 27, 2013 8:27 am |
Comments inline:
union rcv{
char chr_array[8];
//This is the union 'definition'. It says I now have the ability to declare a
//union defined as rcv, but does not declare any variable.....
union rcv fred;
//This now declares the variable 'fred' to be a union, as declared by rcv.
//or for extern,
extern union rcv fred;
//tidier though
typedef union {
char chr_array[8];
} joiner;
//now declares a new 'type', called 'joiner', which you can use to declare
//a variable.
//So:
joiner rcv;
//declares 'rcv' as a union of this type.
extern joiner rcv;
//declares the external variable rcv as a union
aruna1
Posted: Wed Feb 27, 2013 10:39 am |
Ttelmah wrote: | Comments inline:
union rcv{
char chr_array[8];
Thank you very much Ttelmah. I'll give it a try |
carl
Posted: Thu May 02, 2013 9:11 am |
Hi Ttelmah,
I need to do a similar thing, but am struggling with the concept. Basically I have a 32bit 'extern' variable (ival2), that I need byte access to. Usually I would use:
union {
int32 ival2;
int8 bytes[4];
}minvalue;
//minvalue.ival2 = 32bit number;The bytes can now be accessed as:
//minvalue.bytes[0], ..., minvalue.bytes[3]
But how do I do it with the extern? because I cannot use:
Code: | union {
extern int32 ival2;
int8 bytes[4];
}minvalue;
Any help much appreciated.
Carl |
