Re: External oscillator setting and issue with UART
nehallove
PostPosted: Tue Feb 19, 2013 5:59 pm     Reply with quote
Hi All,
System Configuration:
- PIC16F1825
- External Oscillator 3.6864 MHz
We try to use baud rate 115200. For that we can't use internal oscillator, so we are using external oscillator of 3.6864 MHz frequency.
We set the fuses as follow -
#include <16F1825.h>
#device *=16 ICD=TRUE
#device adc=16
#FUSES ECM
#FUSES NODEBUG
#FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
//#use delay(clock=20000000)
#use rs232(baud=115200, xmit=PIN_C4, rcv=PIN_C5)
With this setting uart doesn't work. With old internal clock and 9600 baud rate it does work.
Can anyone point out what we are doing wrong?
Thank you.
nehal
nehal
PostPosted: Tue Feb 19, 2013 6:58 pm     Reply with quote
Where is your #use delay() ? It won't compile without it.
I added the #use delay(), also added ERRORS. It compiles OK with
vs. 4.140. What is your version ?
#device adc=16
#FUSES ECM
#FUSES NODEBUG
#use delay(clock=3.6864M)
#use rs232(baud=115200, xmit=PIN_C4, rcv=PIN_C5, ERRORS)
char c;
c = getc();
putc(c);
