pic 16LF1825 brownout reset when wake up
zmtek
PostPosted: Mon Feb 18, 2013 7:40 am     Reply with quote
I am running following code to wake up from sleep when receiving char
over rs232 on 16F1825 and it is running fine, when programmed
same code to 16LF1825 a brownout reset occuring instead of wake up.
Everything is same - board design, power, hex etc...
the only difference is 16F1825 is DIP package and 16LF1825 is QFN.
the same occurs when i use change on PORT A interrupt for wake
up source.
Any ideas?
#include <16LF1825.h>
#FUSES INTRC_IO,NOWDT,NOPUT,NOMCLR,NOPROTECT,NOCPD,BROWNOUT_NOSL,NOCLKOUT,NOIESO,NOFCMEN,NOSTVREN,BORV19,NODEBUG,NOLVP
#use delay(clock=16000000)
#use rs232 (baud=9600,parity=N,bits=8,xmit=PIN_c4, rcv=PIN_c5)
#bit  WUE_BIT=GETENV("BIT:WUE")
int8 dummy=0;
int8 stat=0;
SETUP_DAC(dac_off);
setup_comparator (nc_nc_nc_nc);
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
setup_ccp1(ccp_off);
setup_vref(VREF_OFF);
setup_spi(SPI_DISABLED );
SETUP_WDT(WDT_OFF);
port_a_pullups(false);
port_c_pullups(false);
stat=RESTART_CAUSE();
printf("Startup reset=%02X\r\n",stat);delay_ms(10);
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_8);
//setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1  |T1_ENABLE_T1OSC);
//setup_timer_1(T1_DISABLED);
//setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
set_tris_a(0b00000000);
set_tris_c(0b00100000);
output_high(PIN_A0);   output_high(PIN_A1);  output_high(PIN_A2);
output_high(PIN_A3);   output_high(PIN_A4);  output_high(PIN_A5);
output_high(PIN_c0);   output_high(PIN_c1);  output_high(PIN_c2);
output_high(PIN_c3);   output_high(PIN_c4);  output_float(PIN_c5);
enable_interrupts(global);
   WUE_BIT=1;
   clear_interrupt(int_rda);       enable_interrupts(int_rda);
   sleep(); delay_cycles(1);
   printf("\r\nwake up\r\n");delay_ms(100);
} //end of main()
#int_RDA
RDA_isr()
dummy=getc();
jeremiah
PostPosted: Mon Feb 18, 2013 3:41 pm     Reply with quote
The LF chip has some low power settings that the F chip does not. I would start there and see if any of the defaults would cause your problem. Also, what voltage are you operating the PIC at?
zmtek
PostPosted: Mon Feb 18, 2013 4:02 pm     Reply with quote
i am running it 3.3v down to 2.5V.. I searched data sheet and errdata but
can not find any setting related to LF version :(
PostPosted: Mon Feb 18, 2013 6:48 pm     Reply with quote
I looked in the errata sheet for the 16LF1825 and there's nothing on
brownout. I also checked all the older revisions of the errata and
there's nothing either.
But it still really sounds like an errata. So I kept checking. I found this
post on the Microchip forum, which is for a PIC in the same family:
http://www.microchip.com/forums/m591855.aspx
I think this errata is what you have. Here's the errata sheet for
the 16LF1826. Read the section on Brownout:
http://ww1.microchip.com/downloads/en/DeviceDoc/80485K.pdf
It also affects the "Brownout Nosleep" mode. It lists some work-arounds
that you can try.
If you can confirm that it's the same errata, you should report it to
Microchip so they can add it to the 16LF1825 errata sheet.
zmtek
PostPosted: Thu Feb 21, 2013 10:44 am     Reply with quote
The solution in 16f1826 errata works (I switched to brownout_sw and switch off brownout before entering sleep mode). Thank you!
I posted the problem in Microchip official forum and I hope they will update the errata.
Best regards
