compiling error
bimba
compiling error
PostPosted: Sun Feb 17, 2013 2:51 pm     Reply with quote
dear all,
Please help me, i don't know why this code wouldn't compile.
thanks
#include <16F877A.h>
#device *= 16
#device adc=8
#fuses HS, NOWDT, NOPROTECT, NOLVP, PUT
#fuses NOBROWNOUT, CPD, NODEBUG, NOWRT
#use delay(clock=10MHz)
#use rs232(baud=1200, xmit=PIN_C6, bits=8, parity=N)
#include <lcd.c>
byte s=0;
lcd_init();
lcd_putc("\f");
setup_adc_ports(adc_clock_internal);
setup_adc(AN0);
set_adc_channel(0);
while(true)
read_adc(adc_start_only);
while(!adc_done());
s = read_adc(adc_read_only);
lcd_gotoxy(1,1);
printf(lcd_putc, "\fTx Data = %u" s);
putc(s);
the error given is that:
Undefined Identifier adc_done
Mike Walne
PostPosted: Sun Feb 17, 2013 3:10 pm     Reply with quote
The CCS manual suggests this to achieve what you appear to want:-
int1 done = adc_done();
while(!done)
  done = adc_done();
Good idea to learn to use the code button.
Mike
bimba
PostPosted: Sun Feb 17, 2013 3:52 pm     Reply with quote
while(!done)
  done = adc_done();
Mike
thanks Mike
on effecting the changes, the new errors are;
A numeric expression must appear here
Unidentified identifier done
W4GNS
PostPosted: Sun Feb 17, 2013 5:07 pm     Reply with quote
Thats odd, neither the OP or the fix by Mike produced errors on my PCWH 4.14
PCWH 4.14
Mike Walne
PostPosted: Sun Feb 17, 2013 5:31 pm     Reply with quote
It's essential to read the forum guide.
Which compiler version are you using?
Mike
bimba
PostPosted: Mon Feb 18, 2013 4:28 am     Reply with quote
Mike
i use version 4.032
thanks
Mike Walne
PostPosted: Mon Feb 18, 2013 7:23 am     Reply with quote
I don't have your compiler version.
However, you were told in response to your previous thread, that v4.032 is at best considered a beta version.
Others have tried your code and report no errors.
So, you need to either re-install your compiler or upgrade.
Mike
bimba
PostPosted: Tue Feb 19, 2013 6:46 am     Reply with quote
Mike
thanks, i just installed version 4.104, and it works fine.
regards to all for your response.
bimba
PostPosted: Tue Feb 19, 2013 9:37 am     Reply with quote
Mike
dear all,
After compiling in CCS C, I took it to proteus, but my LCD won't display anything, it will just lighten up...please help.[http://imageshack.us/photo/my-images/96/similarprj.png/][/url]
