speqakjet IC with PIC
rajm
PostPosted: Sun Feb 10, 2013 11:41 pm     Reply with quote
hi
I'm doing project with speak jet ic in order to speak the content what I'm giving from controller. I have got sample code, but it is in Mikro Pro compiler, in that they have included many header files. But I don't know how to change it for ccs compiler, can anybody help me to do my project ? Here is the code:
main code:
#include <18f4685.h>
//#include <delay.h>
#include <Init_PICMicro.h>
#include <Speakjet_Serial.h>
#include <phonemes.h>
#include <phrases.h>
// SpeakjetTest.c
// Uses P18F4685PIC Micro @8Mhz.  This program is written for the EasyPIC5
// Development Board.
// Speakjet controller on PORTD.
// PORTA pulled high.
// PORTA.RA0 = Speak PB
// PORTA.RA1 = Reset PB
// LCD on PORTB
// Change Speakjet Port assignments in "Speakjet_Serial.h" file.
// Uses Soft_Uart_Init to send serial data to speakjet.
//RC Irace
//6.13.2011
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
//Variable Declarations
//                      12345678901234567890
char Message1[]= "Speakjet   Test ";
char Message2[]= "for P18F4685    ";
char Message3[]= "                ";
char Message4[]= "RA0 to speak....";
char Message8[]= "Transmitting....";
char num[4];
char toggle;
int k;
const char _welcome[] = {_pitchx, 118, 185, 131, 145, 4, 195, 136, 140, 0};
const char _to[] = {_pitchx, 80, 192, 162, 0};
const char _the[] = {_pitchx, 80, 169, 134, 0};
const char _speakjet[] = {_pitchx, 108, 187, 198, 128, 194, 4, 165, 131, 191, 0};
const char _test[] = {_pitchx, 98, 191, 131, 187, 191, 0};
const char _program[] = {_pitchx, 88, 199, 148, 137, 179, 148, 132, 140, 0};
  Init_PICMicro();
  Reset_Speakjet();
  LCD_Out(1, 1, Message1);
  LCD_Out(2, 1, Message2);
  Delay2000ms();
  LCD_Out(2, 1, Message4);
  toggle = 1;
while (1==1)
// ***Button Scanner *******************************************************
  if (PORTA.F0 == 0)
     while (PORTA.F0 == 0)    //  Press to speak phrases
     toggle = toggle ^ 1;
  if (PORTA.F1 == 0)        // Press to Reset,  says "Ready"
     while (PORTA.F1 == 0)
     Reset_Speakjet();
// ***Speech Phrases*********************************************************
  if (toggle == 0)
    LCD_Out(2, 1, Message8);
    Speakjet_Serial(_welcome);
    Speakjet_Serial(_to);
    Speakjet_Serial(_the);
    Speakjet_Serial(_speakjet);
    Speakjet_Serial(_test);
    Speakjet_Serial(_program);
    Delay1000ms();
    Speakjet_Serial(_one);
    Delay1000ms();
    Speakjet_Serial(_two);
    Delay1000ms();
    Speakjet_Serial(_three);
    Delay1000ms();
    Speakjet_Serial(_four);
    Delay1000ms();
    Speakjet_Serial(_five);
    Delay1000ms();
    Speakjet_Serial(_goodbye);
    toggle = 1;
header file:
void Speakjet_Serial(const char s[])
        unsigned char i;
        for (i = 0; s[i] != 0; i++)
    Soft_Uart_Write(s[i]);     // Sends Character Data
    while (speaking == 1)      // If Speakjet already speaking, wait
    Delay10ms();
          return;
} // End Speakjet_Serial
//***********************************************************void Reset_Speakjet()
    RST = 1;
    Delay100ms();
    RST = 0;
    Delay100ms();
    RST = 1;
    Delay100ms();
    return;
void Init_PICMicro()
#define ready    PORTD.F0
#define speaking PORTD.F1
#define RST      PORTD.F2
#define WP       2
         //  76543210
  CMCON  = 0b00000111;
  ADCON1 = 0b00001111;
  TRISA  = 0b00001111;
  TRISB  = 0b00000000;
  TRISC  = 0b10000000;
  TRISD  = 0b00000011;
  TRISE  = 0b00000111;
  Lcd_Init();                 // Initialize LCD EasyPIC5
  LCD_Cmd(_LCD_CLEAR);        // Clear display
  LCD_Cmd(_LCD_CURSOR_OFF);   // Turn cursor off
//Soft_Uart_Init(port, rx, tx, baud_rate, inverted);
  Soft_Uart_Init(&PORTD, 7, 6, 9600, 0);
