watchdog problem (18f67k22)
overmindx
PostPosted: Mon Feb 04, 2013 4:32 am     Reply with quote
hi, can anybody look at this sample code?
#include <18F67K22.h>
#FUSES NOWDT, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, MCLR, RTCOSC_INT
#use delay(clock=16000000)
#use rs232(force_sw,baud=57600, xmit=PIN_G1, rcv=PIN_G2, stream=PC)
#include <stdlib.h>
#include <string.h>
void main(){
   delay_ms(2000);
   fprintf(PC,"start\n");
   setup_wdt(WDT_ON);
   do{
   }while(1);
the output i was hoping was the watchdog would be triggered and it would reset my program. however, it didnt. it just hangs in the while loop even if i have already placed the setup_wdt(WDT_ON). i tried it on a different chip (18f46k20) and it works. can anybody tell me what seems to be the problem here? thanks
PostPosted: Mon Feb 04, 2013 4:47 am     Reply with quote
Read the data sheet.
What does the NOWDT fuse do on this chip?.
Key is that on some chips, you have only two settings. Watchdog on, and watchdog off, but can be enabled in software. On this chip, 'NOWDT', means the watchdog is completely off, and cannot be enabled in software. You need to select 'WDT_SW', which on this chip means the watchdog can be controlled by software.
overmindx
PostPosted: Mon Feb 04, 2013 5:32 am     Reply with quote
thanks for your help Ttelmah... :D
