"Recursion not permitted" Error message
barbiani
PostPosted: Sat Feb 02, 2013 12:07 pm     Reply with quote
Hi everybody,
I am was writing a firmware that was not compiling so I made the smallest version of it that still shows the error.
I think that the compiler is not doing the job right...
Thank you for any tips!
#include <18f4620.h>
typedef void (*task_entry_t)(void); // pointer the thread function
void task_PARENT(void);
task_entry_t PARENT = &task_PARENT;
void task_CHILD(void);
task_entry_t CHILD = &task_CHILD;
void task_CHILD (void) {}
void task_PARENT (void) { CHILD(); }
void main(void) { CHILD(); }
asmboy
PostPosted: Sat Feb 02, 2013 12:30 pm     Reply with quote
what are you trying to accomplish ?
barbiani
PostPosted: Sat Feb 02, 2013 12:33 pm     Reply with quote
Pseudo multitasking... The code was bigger but I removed most of it.
The portion I've posted does not even compile.
asmboy
PostPosted: Sat Feb 02, 2013 12:44 pm     Reply with quote
makes my head spin - redefining "void" in terms of a dereferenced pointer
TO(?) the value of "void" ??
WTF ???? is that about ??
barbiani
PostPosted: Sat Feb 02, 2013 12:48 pm     Reply with quote
no... that is a pointer to a void function.
jeremiah
PostPosted: Sat Feb 02, 2013 2:19 pm     Reply with quote
And you are using correct syntax for it. I use that syntax a lot as well.
I believe the problem is this:
Function pointers are very difficult to handle in the PIC series chip due to hardware limitations, but they are doable. In order to have them work, the CCS compiler calls an internal function (you can see this in the LST file) that takes the address in the function pointer and runs it withing that routine. Trying to run a function pointer within a function pointer requires that you execute that special internal function within another copy of the special internal function, which would be recursion, and the compiler does not do recursion to my knowledge. In short, your function pointers cannot call function pointers if what I understand is correct. You'll probably have to work out a method to keep your function pointers one level deep.
barbiani
PostPosted: Sat Feb 02, 2013 2:29 pm     Reply with quote
Yes. But can you see that the only thing this program does is to call task_CHILD and this function does nothing? I think there is no recursion.
What do you mean by 'one level deep'?
jeremiah
PostPosted: Sat Feb 02, 2013 3:21 pm     Reply with quote
Yes, but with function pointers, unlike normal functions, CCS will look at creating the code for task_PARENT() since it is assigned to a variable, even if that variable is never ever used.
When it creates PARENT, it will create the code for task_PARENT(), which calls CHILD() which is linked to task_CHILD();
So even though you are not calling PARENT yet, the compiler will go ahead and assume you will in order to create the function pointer and assign the task to it.
The process for the PARENT variable IF it were to be called is thus (pseudo code):
call CCS_Internal_Function_Pointer_Caller(PARENT){
    load task_Parent() address;
    run PARENT(){
        call CCS_Internal_Function_Pointer_Caller(CHILD){
           load task_Child() address;
           run CHILD(){
              //child code here
Notice that CCS_Internal_Function_Pointer_Caller() is called within itself (recursion).
Even though you don't call it in the main, by making the function pointer for PARENT and assigning it to task_PARENT(), you are causing the compiler to attempt recursion internally.
EDIT: "one level deep": Notice in my pseudo code how there are 2 "levels" of CCS_Internal_Function_Pointer_Caller()? I refer to that as 2 levels deep. One level deep basically means don't call function pointers within function pointer functions.
barbiani
PostPosted: Sat Feb 02, 2013 3:39 pm     Reply with quote
Now I understand! Thank you for your time and sharing this Smile .
One function calling another was a feature that would simplify the final application a lot.
