PIC16F616 PWM and ADC
jjude
PostPosted: Mon Jan 21, 2013 6:24 am     Reply with quote
Hi.
I need PWM output and ADC input my project.
PWM its OK, but ADC no read voltage and replace PWM duty cycle.
Its my config OK?
#include <16F616.h>
#device adc=8
#FUSES WDT                      //Watch Dog Timer
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPROTECT                //No code protected from reads
#FUSES IOSC4                    //INTOSC speed 4MHz
#FUSES NOMCLR                   //No master Clear pin enabled
#FUSES PUT                      //Power Up Timer
#use fast_io(a)
#use fast_io(c)
#bit ECCPASE = 0x17.7 // PWM start/stop control bit (ECCPAS-register)
#bit ECCPAS0 = 0x17.4 // PWM Autoshotdown enable/disable control bit (ECCPAS-register)
#define S_ETEEN output_low(PIN_C4)
#define S_TAAKSE output_high(PIN_C4)
#define ECCPAS0_LED_OFF output_high(PIN_A0)
#define ECCPAS0_LED_ON output_low(PIN_A0)
#define NOPEUS_MAX 400L
#define NOPEUS_START 60L
#define REFERENSSI 9
int8 kahva;
int8 kahva_old;
int8 ad_tulos;
int8 NOPEUS_OK;
int16 nopeus;
int16 kiihdytys_nopeus;
#include "Aliohjelmat.h"
   set_tris_a(0b111010); // 1=input, 0=output.
   set_tris_c(0b001111);
   output_float(PIN_C0);
   output_float(PIN_C1);
   setup_adc_ports(sAN6 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_16);
   read_adc(ADC_START_AND_READ);
   set_adc_channel(6);
   delay_ms(20);
   setup_wdt(WDT_2304MS);
   restart_wdt();
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,99,1);
   ECCPASE = 1; // PWM-stop
   set_pwm1_duty(0L);
   setup_ccp1(CCP_PWM | CCP_SHUTDOWN_ON_COMP1);
   setup_vref(VREF_HIGH|REFERENSSI);
   setup_comparator(CP1_C3_VREF | CP1_OUT_ON_A2 | CP1_INVERT);
   kahva_old = 0;
   ECCPAS0_LED_OFF;
   ad_tulos = read_adc();
   delay_ms(20);
   ad_tulos = ad_tulos + read_adc();
   delay_ms(20);
   ad_tulos = ad_tulos/2;
   delay_ms(20);
   NOPEUS_OK = 80L;
   if (ad_tulos > 38) NOPEUS_OK = 120L;
   if (ad_tulos > 64) NOPEUS_OK = 160L;
   if (ad_tulos > 89) NOPEUS_OK = 200L;
   if (ad_tulos > 115) NOPEUS_OK = 240L;
   if (ad_tulos > 140) NOPEUS_OK = 280L;
   if (ad_tulos > 166) NOPEUS_OK = 320L;
   if (ad_tulos > 192) NOPEUS_OK = 360L;
   if (ad_tulos > 217) NOPEUS_OK = 400L;
Mike Walne
PostPosted: Mon Jan 21, 2013 10:54 am     Reply with quote
How do you KNOW what's working and what's not?
Is this real hardware or simulation?
Make the whole thing simpler.
Reduce your code to the minimum.
Be consistent with your variable names, (you've got a mix of upper and lower cases).
Mike
jjude
PostPosted: Mon Jan 21, 2013 12:13 pm     Reply with quote
Mike
I see that the oscilloscope pwm works.
But by changing the voltage of the ADC does not change dutycycle.
Correct device is.
An earlier version of the program was changed from dutycycle program
code and this will not work
PostPosted: Mon Jan 21, 2013 1:20 pm     Reply with quote
#device adc=8
int8 ad_tulos;
int8 NOPEUS_OK;
delay_ms(20);
delay_ms(20);
delay_ms(20);
NOPEUS_OK = 80L;
You have been on this forum since 2007 and you still don't know the
size of CCS data types, and the largest numbers they can hold.
It's essential to know these things.
#FUSES WDT
You shouldn't use Watchdog timer in a program that is still being
developed.
Mike Walne
PostPosted: Mon Jan 21, 2013 2:43 pm     Reply with quote
This link shows a program which uses ADC to control PWM.
(Courtesy of PCM programmer)
http://www.ccsinfo.com/forum/viewtopic.php?t=40007&start=1&postdays=0&postorder=asc&highlight=
You'll need to change the chip.
What more do you need?
Mike
jjude
PostPosted: Tue Jan 22, 2013 1:29 am     Reply with quote
I'm sorry!
The code works just fine, the problem was the rest of the code.
