Variable for value in setup_vref not working
sirmeowsalot
PostPosted: Fri Jan 18, 2013 5:56 pm     Reply with quote
So I want to vary the value of vref in the project I'm working on, but I'm finding that something like:
int vtest = 10;
setup_vref(VREF_OUT_CVREF | VREF_C1_HIGH | vtest);
won't work at all, but this:
setup_vref(VREF_OUT_CVREF | VREF_C1_HIGH | 10);
works just fine.
Any ideas on why or how I can get it to work?
edit:
ICD3
PIC16F785
MPLAB X
PostPosted: Fri Jan 18, 2013 9:45 pm     Reply with quote
What is your CCS compiler version ? This problem is likely dependent
upon the version.
The version is a 4-digit number given at the top of the .LST file.
The .LST file is generated after a successful compilation and will be
in your project directory. Examples of version numbers:
http://www.ccsinfo.com/devices.php?page=versioninfo
sirmeowsalot
PostPosted: Mon Jan 21, 2013 12:12 pm     Reply with quote
Thanks for the response, PCM programmer!
Looks like we're running 4.130
Should I see if I can get them to update/upgrade? Can anyone verify that it works with a newer version of the compiler?
PostPosted: Mon Jan 21, 2013 1:22 pm     Reply with quote
If someone else doesn't check if the version makes a difference in the
generated code, I do it in about 6 hours from now. I can't do it at my
present location.
sirmeowsalot
PostPosted: Mon Jan 21, 2013 6:20 pm     Reply with quote
Awesome! Thanks in advance!
PostPosted: Mon Jan 21, 2013 8:25 pm     Reply with quote
There is a bug in vs. 4.130 for setup_vref() for the 16F785. The code
doesn't load the REFCON register correctly. The bug still exists in vs. 4.140.
0017:  MOVLW  0A    // 10 -> Wreg
0018:  BCF    03.6
0019:  MOVWF  25    // Wreg -> vtest
.................... int vtest = 10;
.................... setup_vref(VREF_OUT_CVREF | VREF_C1_HIGH | vtest);
001A:  MOVF   25,W  // main.vtest -> Wreg
001B:  IORLW  80    // OR Wreg with VREF_C1_HIGH (0x80)
001C:  MOVWF  26    // Wreg -> main.@SCRATCH1
001D:  MOVLW  02    // VREF_OUT_CVREF (02) -> Wreg
001E:  MOVWF  27    // Wreg -> main.@SCRATCH2
001F:  MOVF   26,W  // main.@SCRATCH1 -> Wreg
0020:  BSF    03.5
0021:  MOVWF  19    // Wreg -> VRCON
0022:  MOVF   00,W  // INDF -> Wreg  *** Bug - should load from @SCRATCH2
0023:  MOVWF  18    // Wreg -> REFCON
.................... setup_vref(VREF_OUT_CVREF | VREF_C1_HIGH | 10);
0024:  MOVLW  8A
0025:  MOVWF  19   // VRCON = 0x8A
0026:  MOVLW  02
0027:  MOVWF  18   // REFCON = 0x02
Here is a macro that will replace the built-in setup_vref() function.
Place the macro code above main(), as shown below, and then
call setup_vref().
#include<16F785.h>
#fuses INTRC_IO,NOWDT
#use delay(clock = 4M)
#byte VRCON = getenv("SFR:VRCON")
#byte REFCON = getenv("SFR:REFCON")
int16 temp16;
#define setup_vref(value)  \
temp16 = value;       \
VRCON = temp16;       \
REFCON = temp16 >> 8
int vtest = 10;
sirmeowsalot
PostPosted: Tue Jan 22, 2013 1:45 pm     Reply with quote
Awesome! You rock, PCM programmer!
Thanks for the macro!
Not very good at assembly so I couldn't figure out what it was doing differently when I took a look earlier, so thanks for the explanation on that as well!
bkamen
PostPosted: Tue Jan 22, 2013 5:57 pm     Reply with quote
This is why it's a good thing to learn assembler - for future reference.
Little things like this will become easy to find and easy to fix.
I recently ran into a similar problem with setup_vref on the PIC24 series with PCD.
setup_vref was writing to the wrong register.
-Ben
