write_eeprom source code
titus
PostPosted: Wed Jan 16, 2013 1:43 am     Reply with quote
Can anyone know where can I find source code for write_eeprom and read_eeprom functions?
I'm using CCS v4.02.
Thank you very much,
Roberto
PostPosted: Wed Jan 16, 2013 3:31 am     Reply with quote
There isn't.
These are written in assembler, not C, and basically exactly match the examples given in the Microchip notes. Turn off nolist, and look at the generated assembler.
The same applies to almost all the internal functions.
titus
PostPosted: Wed Jan 16, 2013 7:28 am     Reply with quote
Thank you for your answer,
I look at the assembly code but didn't found something looks like reading and writing to and from EEPROM.
I saw that someone wrote the following function:
unsigned char ReadEEPROM (unsigned char address)
    EECON1=0;                   //ensure CFGS=0 and EEPGD=0
    EEADR = address;
    EECON1bits.RD = 1;
    return(EEDATA);
void WriteEEPROM (unsigned char address,unsigned char data)
    char SaveInt;
    SaveInt=INTCON;             //save interrupt status
    EECON1bits.WREN = 1;        //enable write to EEPROM
    EEADR = address;            //setup Address
    EEDATA = data;              //and data
    INTCONbits.GIE=0;           //No interrupts
    EECON2 = 0x55;              //required sequence #1
    EECON2 = 0xaa;              //#2
    EECON1bits.WR = 1;          //#3 = actual write
    INTCON=SaveInt;             //restore interrupts
    while(!PIR2bits.EEIF);      //wait until finished
    EECON1bits.WREN = 0;        //disable write to EEPROM
In this code there are some command that I don't know if they exist in the assembly code. Such as "wait until finish", enable/disable interrupts etc.
Therefore I need to know how exactlly the write_eeprom and read_eeprom function works.
Roberto
PostPosted: Wed Jan 16, 2013 8:32 am     Reply with quote
Of course they exist, the functions wouldn't work if they didn't.
Have a look in the data sheet for (say) the PIC16F877. Section 4-3 'writing to the EEPROM data memory'.
Then compiler a single line program, calling write_eeprom, and look at the assembler generated.
The only difference, is that the CCS code (as your version does), waits for write to finish after writing a byte, while the example, checks and waits before writing a byte (more efficient at heart, since you can then get on with other things while the write is actually occurring).
The code you have, has a potential fault, checking EEIF, rather than the WR bit.
You need also to be aware, that the function will _differ_ on some other chips.
titus
PostPosted: Wed Jan 16, 2013 8:39 am     Reply with quote
Thank you again Ttelmah,
So after all I'll stick with CSS functions.
Best regards,
Roberto
Roberto
PostPosted: Wed Jan 16, 2013 8:59 am     Reply with quote
Just 'FYI', I've documented the standard function:
....................    write_eeprom(0,0xFF);
0033:  BCF    03.5     //bank selection
0034:  MOVF   0B,W  //load the contents of the INTCON register
0035:  MOVWF  77    //save it
0036:  BCF    0B.7    //Turn off GIE
0037:  BSF    03.6    //bank selection
0038:  CLRF   0D      //0 to EEDATA (different if we write a variable)
0039:  MOVLW  FF
003A:  MOVWF  0C   //0xFF to EEADR (again different if a variable is used)
003B:  BSF    03.5    //bank selection
003C:  BCF    0C.7    //select EEPROM as write target
003D:  BSF    0C.2    //enable writes
003E:  MOVLW  55    //Now send the trigger sequence
003F:  MOVWF  0D    //0x55 to EECON2
0040:  MOVLW  AA
0041:  MOVWF  0D    //and then 0xAA
0042:  BSF    0C.1   //trigger the write to start
0043:  BTFSC  0C.1   //Now test the WR bit
0044:  GOTO   043    //Loop till it clears - write complete
0045:  BCF    0C.2   //turn off the write enable
0046:  MOVF   77,W  //load value that was in INTCON
0047:  BCF    03.5   //switch banks again
0048:  BCF    03.6
0049:  IORWF  0B,F //turn GIE back on if it was on originally
It really does do everything.
CCS had some problems with functions, something like 10+ years ago, and do still have problems sometimes with new features on new chips, but the standard functions have been basically 'solid' for many years.
