Anyone use output_toggle() yet? Is it the same as output_high() (as noted in readme.txt), or will it toggle the output pin (low to hi or hi to low).
Mark
Posted: Mon Sep 08, 2003 7:00 am
There is a BTG (Bit Toggle f) asm instruction on the PIC18's. CCS probably is making use of this for the PCH compiler. My guess is that if you are using the other compilers then there is first a check and then the either and output_low() or output_high() is executed.
SherpaDoug
The ultimate answer...
The ultimate answer is to write a trivial program using the function and look at the list file to see what it tells the processor to do. If you find something unexpected please let us know. _________________ The search for better is endless. Instead simply find very good and get the job done.
