18LF25k22 oscillator too fast
theteaman
PostPosted: Wed Jan 02, 2013 1:50 am     Reply with quote
Hi
I am using an 18LF25K22 with the fuses
#use delay(clock=20000000, crystal=20000000)
#fuses NOWDT, WDT128, HSH, NOIESO, BROWNOUT, PUT, NOSTVREN, NODEBUG, NOLVP, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOPBADEN
and a 20MHz crystal. I set a pin to alternate between high and low every 5000 milliseconds with delay_ms(5000). But on my scope I can clearly see the signal's period is just over 1 second...
VDD is 4.5V.
I'm curious as to why it just won't go at the right speed? Any help appreciated, thanks.
PostPosted: Wed Jan 02, 2013 2:30 am     Reply with quote
Add NOPLLEN
The default fuse has the PLL enabled, _unless_ you say otherwise. You can always tell by looking at the bit patterns selected at the end of the .LST file, and checking these against the data sheet. It is designed to confuse, since on most chips the default is for the PLL to be 'off'.
Impressive actually that the chip runs at 80MHz.... ;)
theteaman
PostPosted: Wed Jan 02, 2013 2:41 am     Reply with quote
You sir, just saved me hours more confusion! Thank you! I never thought that the PLL default could be different for different devices.
Thanks again.
