I'm trying to get fprintf function working only when DEBUG is defined. This worked ok for printf, but it seems I can't get the right prototype for fprintf function.
I get compiler error: "Attempt to create a pointer to a constant"
Is there any better way to do it? I would like to have debug_printf function that I can use as a standard printf. For example:
void debug_printf(char *format, ...){
#IFDEF DEBUG
fprintf(RS232_DEBUG, ........); // I'm not sure how to pass all parameters to fprintf function
#ENDIF
Mike Walne
Thank you Mike for the link. For now, gribas proposed best solution with #define trace... I was hoping for a little bit more elegant solution, but this will do.
