functions inserted multiple times in code space
gil.fonea@sds-tech.com
PostPosted: Thu Dec 27, 2012 5:43 am     Reply with quote
Compiling a CCS (ver 4.099) project for 18F85J90 and looking into the MPLAB disassembly listings shows that printf (and other functions) code appears as many times as it's called in the code. This occupies a lot of code space.
Is there anyway to avoid this (just call the function address in the code-space)?
Regards,
Gil
Gil F.
asmboy
PostPosted: Thu Dec 27, 2012 1:20 pm     Reply with quote
You are most likely seeing CCS automatic #inline optimization based on your program having an overall small amount of object code.
This is normal behavior and makes your program execution be as fast as possible - since remote function/procedure calls take many more machine cycles than this in lining, and WORSE potentially cause excessive stack nesting failure in runtime. ( newer compiler versions I think do profile for this last problem in the call tree - but not dead sure ).
I urge you to read the CCS manual re:
#INLINE and
#SEPARATE
summary: don't worry, be happy Very Happy Very Happy
PostPosted: Thu Dec 27, 2012 3:05 pm     Reply with quote
Here are some threads on the topic:
Looking for tips for reducing ROM footprint:
http://www.ccsinfo.com/forum/viewtopic.php?t=43389
Using a wrapper function:
http://www.ccsinfo.com/forum/viewtopic.php?t=39784
http://www.ccsinfo.com/forum/viewtopic.php?t=43683
http://www.ccsinfo.com/forum/viewtopic.php?t=48256
