Timer0 and timer1 function (flag bit how to deal )
leevise
PostPosted: Wed Dec 19, 2012 7:08 pm     Reply with quote
Hello guys
I used the timer0 and timer1 as timer clock, but I use the PICC code. Now I need make it to CCS code, there are some questions when I translate the code.
1) how to open or close the Timer1 using CCS ? (PICC can control T1ON bit of T1CON register come true this function).
2) how to set two flags bit to timer0 and timer1 in CCS, as PICC TIM0IF and TIM1IF ?
the part of PICC code :
*********timer0/timer init********/
void  timer_init()
   GIE=1;
   PEIE=1;
   T0CS=0;
   PSA=0;
   PS0=1;
   PS1=1;
   PS2=1;                //1:256
   T0IE=1;
       TMR0=248;         //2ms
   T1CKPS0=1;T1CKPS1=1;      //1:8
   TMR1CS=0;
   TMR1IE=1;
   [B]TMR1ON=1;   [/B]
   TMR1H=0xfb;            //10ms
   TMR1L=0x1e;            //
/********interrupt ********/
void interrupt ISR(void)
   [B]if (TMR0IF==1)[/B]
      TMR0IF=0;
      TMR0=248;         //TMR0 2ms
      Display();
   [B]if (TMR1IF==1)[/B]
      TMR1IF=0;         //
      TMR1H=0xfb;         //10ms
      TMR1L=0x1e;
      count_10ms++;      //10ms+1
      if(count_10ms >= 100)
         count_10ms = 0;         //
         sec++;               //sec+1
         if(sec == 60)
            sec = 0;
            min++;         //min+1
            if(min ==60)
               min = 0;
               hour++;      //hour+1
               if(hour ==24)
                  hour = 0;min=0;sec=0;
/********Key********/
void  KeyProcess()
   TMR1ON=0;         //press K1,T1 open
   if(K2==0)            //press K2
      Delay_ms(10);
      if(K2==0)
         while(!K2);      //wait K2 release
         beep();
         hour++;      //adjust hour
         if(hour==24)
            hour = 0;
   if(K3==0)            //press K3
      Delay_ms(10);
      if(K3==0)
         while(!K3);      //K3 release
         beep();
            min++;      //adjust min
         if(min==60)
            min = 0;
   if(K4==0)            //press K4
      Delay_ms(10);
      if(K4==0)
         while(!K4);      //waiting for K4 release
         beep();
         TMR1ON=1;      //TI start
         K1_FLAG=0;      //flag=0
/********main********/
   port_init();
   timer_init();
      if(K1==0)
         Delay_ms(10);
         if(K1==0)
            while(!K1);
            K1_FLAG=1;                  }
      if(K1_FLAG==1)KeyProcess();
      conv(hour,min,sec);
I translate the PICC code to CCS code as follow:
#int_timer0
void  timer0_init()
 static int flag;
 if (flag==1)//(TMR0IF==1)
      flag=0;//TMR0IF=0;
      set_timer0(0xf8); //TMR0=248;
      Display();
 #int_timer1
 void  timer1_init()
   static int flag;
   if (flag==1)
     [B] flag=0;// is this define process? [/B]
      set_timer1(0xfb);
      /*TMR1IF=0;         //
      TMR1H=0xfb;         //
      TMR1L=0x1e;         //
       count_10ms=0;
      count_10ms++;
         count_10ms = 0;
         sec++;
         if(sec == 60)
            sec = 0;
            min++;
            if(min ==60)
               min = 0;
               hour++;
               if(hour ==24)
void  KeyProcess()
   setup_timeR_1(T1_DISABLED);//=0;
   if(key1==0)
      delay_ms(10);
      if(key1==0)
         while(!key1);
         //beep();
         hour++;
         if(hour==24)
            hour = 0;
   if(key2==0)
      delay_ms(10);
      if(key2==0)
         while(!key2);
         //beep();
            min++;
         if(min==60)
            min = 0;
   if(key3==0)
      delay_ms(10);
      if(key3==0)
         while(!key3);
         //beep();
         setup_timeR_1(T1_INTERNAL);
         key0_FLAG=0;
   port_init();
    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
    set_timer0(0xf8);    //TMR0 2ms
    set_timer1(0xfb);
    enable_interrupts(int_timer0);
    enable_interrupts(int_timer1);
    enable_interrupts(global);
      if(key0==0)
         delay_ms(10);
         if(key0==0)
            while(!key0);
            Key0_FLAG=1;
      if(key0_FLAG==1)KeyProcess();
      conv(hour,min,sec);
pls explain me about these questions!
Thank you Crying or Very sad Crying or Very sad Crying or Very sad
PostPosted: Thu Dec 20, 2012 5:45 am     Reply with quote
#int_timer0
void  timer0_int() //Um. It is an interrupt, not an initialisation
    //Er. If the interrupt is called, then TMR0IF, will always be set
    //The compiler automatically clears it.
    Display();
//Now, you don't show us 'Display'.
//Same basic layout for timer1, with a couple of extra point
//When you declare 'count_10msec', use:
int8 count_10mSec=0;
//This does the initialisation to zero, which you have put into the ISR...
#int_timer1
void timer1_int() {
    set_timer1(0xFB1E); //you need both bytes - 16bit value...
    //why are you then clearing count_10ms?. This does not happen in the
    //assembler ISR. It needs to be where it is initialised.
etc...
Comments:
The CCS msec delay function, is 'delay_ms', not 'Delay_ms'. This will cause problems if you switch to use case significant mode. You have similar case problems with 'setup_timeR_1'
leevise
PostPosted: Thu Dec 20, 2012 7:47 am     Reply with quote
I make a clock via segment display. The code was programed by PICC, but I want to translate to CCS code,there are some flag bit is used in PICC, but how to translating CCS code ? pls help me
about CCS code ,I found some one use the "sTatic int flag", is it not pre-define?there is a syntax "clear_interrupt(timer0)", maybe use this ?
oh my god ,I am very puzzle!
when used the TOMER0 and TIMER1, and we need 2 flag bit ,how to distinguish which is TOMER0' TOIF bit ,which one is the TIMER1' T1IF bit? , i am very puzzling
Another question: how to open or closed the TION by CCS code ? is it "setup_timer_1(T1_DISABLED);
and set_timer_1(xxxxxx)"?
#include<pic.h>
#define uchar unsigned char
#define uint  unsigned int
__CONFIG(HS&WDTDIS&LVPDIS);
uchar hour=12,min=00,sec=00;   //define hour, min ,second
uchar count_10ms;          //define 10ms counter
#define   K1  RB2         //define K1
#define   K2  RB3         //define K2
#define   K3  RB4         //defineK3
#define   K4  RB5         //defineK4
#define   BEEP  RE0         //define beep
uchar K1_FLAG=0;         //define press key flag,when pressed K1,the flag set 1,un-press K1,the bit is 0
uchar const bit_tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//select which one                    segment works
uchar const seg_data[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff,0xbf};
uchar disp_buf[8];            //define a buffer
void port_init(void)
OPTION=0x00;       //port b pull up
TRISC = 0x00;         //set port c output
    TRISD = 0x00;         //portd data output
ADCON1=0x06;      //
    TRISE=0x00;          //(RE0)
PORTE=0xff;
void Delay_ms(uint xms)
    int i,j;
    for(i=0;i<xms;i++)
       { for(j=0;j<71;j++) ; }
/*********buzzer function********/
void  beep()
  BEEP=0;             //buzzer ring
  Delay_ms(100);
  BEEP=1;              //shut off buzzer
  Delay_ms(100);
/********segment convert function********/
void conv(uchar in1,uchar in2,uchar in3)      //set parameters in1、in2、in3can receive the hour、min、sec
   disp_buf[0] =in1/10;      // dicimal of hour
   disp_buf[1] = in1%10;      // figure of hour
   disp_buf[3] = in2/10;      // minute's dicimal
   disp_buf[4] = in2%10;      // minute's figure
   disp_buf[6] = in3/10;      //second's dicimal
   disp_buf[7] = in3%10;      // second's figure
   //disp_buf[2] = 17;         // display"-"
   disp_buf[5] = 17;         // display"-"
void Display()
   uchar tmp;            //
   static uchar disp_sel=0;      //
   tmp=bit_tab[disp_sel];      //
   PORTC=tmp;            //
   tmp=disp_buf[disp_sel];      //
   tmp=seg_data[tmp];
   PORTD=tmp;            //
   disp_sel++;            //
   if(disp_sel==8)
   disp_sel=0;            //
void  timer_init()
   GIE=1;               //
   PEIE=1;
   T0CS=0;
   PSA=0;
   PS0=1;
   PS1=1;
   PS2=1;               //IMER0 Prescaler 1:256
   T0IE=1;            //overflow enable
   TMR0=248;            //TMR0 assignment 2ms
   T1CKPS0=1;T1CKPS1=1;      //timer1 prescaler1:8
   TMR1CS=0;            //
   TMR1IE=1;            //
   TMR1ON=1;            //open the timer1 interrupt
   TMR1H=0xfb;            //10ms
   TMR1L=0x1e;            //
   if (TMR0IF==1)
      TMR0IF=0;         //clear TMR1 overflow flag
      Display();         //callback display function
   if (TMR1IF==1)
      TMR1IF=0;         //clear TMR1 over flow flag
      TMR1H=0xfb;         //,timing time 10ms
      TMR1L=0x1e;         //
         count_10ms = 0;   //judge  if the counter get to100
         sec++;               //
         if(sec == 60)
            sec = 0;
            min++;         //if reach the 60second,then minute add 1
            if(min ==60)
               min = 0;
               hour++;      //if reach 60 minute,then hour will add 1
               if(hour ==24)
                  hour = 0;min=0;sec=0; //
void  KeyProcess()
   TMR1ON=0;            //if press K1,then shut down T1,clock pause
   if(K2==0)            //if press K2
      Delay_ms(10);      //eliminating the signal-wobble
      if(K2==0)
         while(!K2);      //waiting for K2 release
         beep();
         if(hour==24)
            hour = 0;
   if(K3==0)            //if press K3
      Delay_ms(10);
      if(K3==0)
         while(!K3);      //waiting for K3 release
         beep();
            min++;      //adjust minute
         if(min==60)
            min = 0;
   if(K4==0)            //if press K4
      Delay_ms(10);
      if(K4==0)
         beep();
         TMR1ON=1;      //after adjusting ,clock go on
         K1_FLAG=0;      //when press K1 ,the flag become 0
   port_init();
   timer_init();
      if(K1==0)            //
         Delay_ms(10);      //
         if(K1==0)
            while(!K1);      //
            beep();         //
            K1_FLAG=1;
      conv(hour,min,sec);
Sad Sad Sad Sad Sad Sad Sad Sad
leevise
PostPosted: Fri Dec 21, 2012 1:07 am     Reply with quote
Ttelmah wrote:
#int_timer0
    Display();
#int_timer1
void timer1_int() {
etc...
Comments:
Oh, thank you for your advice.
but the PICC code is as follow:
   if (TMR0IF==1)
   if (TMR1IF==1)
      TMR1L=0x1e;         //
         sec++;               //
         if(sec == 60)
            sec = 0;
            if(min ==60)
               min = 0;
               if(hour ==24)
How to deal it with CCS code ?I don't know what to do.
pls guide me translate the PICC ISR code to CCS int code.
PostPosted: Fri Dec 21, 2012 2:55 am     Reply with quote
Seriously, use your eyes, brain, manual and examples:
This:
   if (TMR0IF==1)
//does exactly the same as (in CCS C), this:
#int_timer0
void  timer0_int() {
    Display();
The compiler tests the interrupt flag, and only calls this routine, if TMROIF==1. It also clears the interrupt flag for you.
We are not here to write the code for you. I've shown what needs to change, do it.
leevise
PostPosted: Fri Dec 21, 2012 7:18 am     Reply with quote
This:
   if (TMR0IF==1)
#int_timer0
void  timer0_int() {
    Display();
Thank you. I understand your means. My main puzzle is the interrupt flag in the past. Now I am ok. Razz
