delay function using timer 1
giaanthunder
PostPosted: Wed Dec 19, 2012 3:15 am     Reply with quote
Hi everybody! i am trying to make a delay function like delay_ms() using timer 1 with pic 16f877a, but it didnt work at all. im using 4mhz xtal and the simulation was stuck at the line PORTD=0xff;
help me please
#include <main.h>
#include <def_877a.h>
void mydelay (int16 x)
   int8 i=0;
   for(i=0;i<x;i++)
      set_timer1(0);
      while(get_timer1()!=1000);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);      //65.5 ms overflow
   TRISD=0;
   PORTD=0;
      PORTD=0xff;
      mydelay(500);
      PORTD=0;
      mydelay(500);
Mike Walne
PostPosted: Wed Dec 19, 2012 4:02 am     Reply with quote
Several things:-
1) You don't tell us which simulator.
2) How long does it take to perform this test? " while(get_timer1()!=1000); "
3) How long does timer1 stay in the condition where timer1 is 1000?
4) #FUSES
5) Compiler version
6) ......................
Mike
giaanthunder
PostPosted: Wed Dec 19, 2012 4:21 am     Reply with quote
1/ im using protues to flash 8 led
2/ while(get_timer1()!=1000); make the pic delay until the timer1 reach 1000 (1000us=1ms) b/c i using 4mhz xtal so it take 1us to increase timer1 by 1. i think so.
3/ when timer1 reach 1000, i think it will do the next statement immediately
4/this is file .h:
#include <16F877A.h>
#device adc=16
#FUSES NOWDT, HS, NOPUT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, NOPROTECT
5/v4.114
PostPosted: Wed Dec 19, 2012 4:48 am     Reply with quote
Start with i.
How can it count to 500?.....
You will potentially get problems reading the timer like this. Better to use the interrupt flag (not the interrupt). So:
void mydelay (int16 x) {
   int16 i; //...... Also no point in wasting time initialising it
   for(i=0;i<x;i++) {
      set_timer1(-1000);
      clear_interrupt(INT_TIMER1);
      while(!interrupt_active(INT_TIMER1)); //wait for the interrupt
Problem is that the 'read' is of two separate bytes. To ensure that one hasn't changed while you have read the other, the compiler has to check if the MSB has changed since the LSB as read, making the read very slow (takes typically 12+ machine cycles). Then testing a 16bit value involves another half dozen cycles. The interrupt bit is read and tested in just one cycle.
Mike Walne
PostPosted: Wed Dec 19, 2012 5:07 am     Reply with quote
4/this is file .h:
#device adc=16
5/v4.114
1) Forget Proteus. I wont even install it. Read other's comments on this forum.
2) You answered the wrong question. I asked how long will it take to do the test, NOT how long will it take for timer1 to reach 1000.
Ttelmah has explained it's highly likely the test will never produce a true result.
In other words, you're doing the wrong test.
Testing for get_timer1()<1000 might have worked better.
3) Yes, timer1 will only be 1000 for 1us with your crystal and timer1 setting.
The test you were doing takes much longer, so you were more likely to miss than hit.
If you must simulate use MPLAB.
Better to use REAL hardware.
Mike
giaanthunder
PostPosted: Wed Dec 19, 2012 5:17 am     Reply with quote
thank you so much Very Happy
I fix this code for hours but dont realize the problem was i, a very basic mistake Very Happy
the idea using interrupt flag is so good.
giaanthunder
PostPosted: Wed Dec 19, 2012 5:43 am     Reply with quote
thanks Mike Very Happy
for example----
PostPosted: Wed Dec 19, 2012 3:25 pm     Reply with quote
// 18F family code - 8 mhz INTOSC 2mhz OP clock
//      setup_timer_0( RTCC_DIV_8|RTCC_8_BIT );  //  rollovers 1.024 ms ms 8 mhz
//      setup_timer_0( RTCC_DIV_16|RTCC_8_BIT );  // rollovers 2.048 ms ms 8 mhz
//      setup_timer_0( RTCC_DIV_32|RTCC_8_BIT );  // rollovers 4.096 ms ms 8 mhz
// wait for delay by appx mytix milliseconds
void msdelay(unsigned int16 mytix){
      if (!mytix) return;  // trap zero argument
      setup_timer_0( RTCC_DIV_8|RTCC_8_BIT );  // set for rollovers 1.024 ms ms
      set_timer0(0);
      T0IF = 0;  // one more 1 ms delay
      DO {
        while (!T0IF) { };
        // --- this segment will execute every 1.024 msec
        T0IF=0;
        --mytix;
       // -- and any POLLING operation that  runs less than a msec
       //  can be placed here
      } while (mytix);
Since I use timer0 for other stuff when not doing this timer bit -
I set it up for the delay I want at each use.
