General LCD question
benni
PostPosted: Tue Dec 18, 2012 11:12 am     Reply with quote
Hello Guys,
I've just got a simple question:
Would this code work if i connect everything right?:
main.c
#include <main.h>
#define LCD_ENABLE_PIN  PIN_B3
#define LCD_RS_PIN      PIN_B2
#define LCD_RW_PIN      PIN_B1
#define LCD_DATA4       PIN_B4
#define LCD_DATA5       PIN_B5
#define LCD_DATA6       PIN_B6
#define LCD_DATA7       PIN_B7
#include <lcd.c>
   lcd_init();
   lcd_putc("\fReady...\n");
   lcd_putc("Hello Benni");
main.h
//#include <18F4550.h>
#include <16F887.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOPUT
#FUSES NOMCLR                     //Master Clear pin enabled
AND:
Why they are Resistors at RB7 and RB6 in this schematic:
http://www.best-microcontroller-projects.com/support-files/serial-lcd.pdf
Here is a other schematic without Resistors:
Thanks for help!
Regards Benni.[/code]
PostPosted: Tue Dec 18, 2012 11:36 am     Reply with quote
quickly...
1) no.......
The program is not complete.
You need a processor type as well as 'fuses'.
You must have the LCD pin defines before loading the LCD driver,otherwise the default values(within the driver) will be used.
2) the resistors are used to 'isolate' the ICSP pins RB7,RB6.
benni
PostPosted: Tue Dec 18, 2012 11:41 am     Reply with quote
Hey,
I've updated the first post, I found another schematic and updated the code.
Is it right now?
Regards Benni
PostPosted: Tue Dec 18, 2012 1:47 pm     Reply with quote
no...
1) schematic shows 4 MHz xtal..code say 20MHz.
2) schematic shows 16F877..code says 16F887.
3) some fuses are wrong, ie: nomclr yet comment says enabled
4) LCD lower nibble pins grounded ? May or may not work,depends on LCD module.
bottom line...
wire up the board, compile the code, burn the PIC, see what happens..
hth
jay
benni
PostPosted: Tue Dec 18, 2012 2:08 pm     Reply with quote
I am using a 20 MHz crystal, the schematic is just from the internet. I just want to know how to connect it right.
The PIC is also a 16f887 and not a 16F877.
So it should work. We will see it. When I'm done I will post something here.
Thanks.
Regards Benni
PostPosted: Tue Dec 18, 2012 4:06 pm     Reply with quote
Other comment, put the first delay _before_ lcd_init.
Some LCD's do not start to wake up till the supply gets to nearly 5v. The PIC starts to wake much earlier. Most LCD's require quite a long delay before the initialisation, and some of the clones require more than 'standard'. Add the wake-up sequencing, and a good long delay before trying to send anything often helps....
Also, grounding the lower nibble, will just waste power. If you check the data sheet for most LCD's, these lines are _pulled up_ in the LCD, so they can be left disconnected.
benni
PostPosted: Sat Dec 22, 2012 10:58 am     Reply with quote
Hello
I am not getting it to work, the background of the LCD is working but it doesn't shows the Text.
Here is the code:
#include <main.h>
#define LCD_TYPE 2
#define LCD_RS_PIN      PIN_B7
#define LCD_RW_PIN      PIN_B6
#define LCD_ENABLE_PIN  PIN_B5
#define LCD_DATA5       PIN_B3
#define LCD_DATA6       PIN_B2
#define LCD_DATA7       PIN_B1
#include <lcd.c>
 delay_ms(5000);
   lcd_init();
   delay_ms(3000);
   printf(LCD_PUTC, "\fHello Benni");
Does someone knows an idea why its not working?
Regards Benni
benni
PostPosted: Sat Dec 22, 2012 12:23 pm     Reply with quote
Thanks for Help.
It's now working i thought RB0 was RB7 and so on, i just wired it wrong.
Here are pictures:
Regards Benni
