PIC24FJ USB FUSES
Damaso
PIC24FJ USB FUSES
PostPosted: Fri Dec 14, 2012 6:06 am     Reply with quote
I'm starting a simple project using a PIC24FJ128GB106 with USB support and I'm a little lost on which fuses should I use and why. I'm going to use an external 20MHz crystal, so I suppose I need to divide it by 5.
I'm not sure if these are correct:
#FUSES ICSP2 //ICD uses PGC2/PGD2 pins
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES PR_PLL //Primary Oscillator with PLL
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
tae
PostPosted: Fri Dec 14, 2012 7:12 am     Reply with quote
That's right, just need to remember is to include PLL
#FUSES PLL96MHZ
Damaso
PostPosted: Mon Dec 17, 2012 6:35 am     Reply with quote
With that additional fuse, does the code run at 20MHz? And does the USB module works correctly?
