18f4580 PWM config
Lemosek
18f4580 PWM config
PostPosted: Sun Dec 16, 2012 8:20 am     Reply with quote
I need a PWM on pin P1A(RD4). This is output ECCP.
I don't know how I must configure this module.
I tried something like this:
// TImer2 used for system ticks
// post = 4, period = 250*4*5* 0.2 us = 1 ms
#define T2CON_CONST     T2_DIV_BY_4
#define PR2_CONST       (250-1)
#define T2POST_CONST    5
setup_timer_2(T2CON_CONST, PR2_CONST, T2POST_CONST);
SETUP_CCP1(CCP_PWM_H_H);
SET_PWM1_DUTY(100);
But not working.
Best regards
R.L.
PostPosted: Sun Dec 16, 2012 10:13 am     Reply with quote
The ECCP is reverse compatible. To use the default pin, just use:
SETUP_CCP1(CCP_PWM);
Key thing is though, you must have turned off the PSP port:
SETUP_PSP(PSP_DISABLED);
or this will have control of the port pins.
Lemosek
PostPosted: Sun Dec 16, 2012 11:37 am     Reply with quote
Thank You Ttelmah now it's working but I must also change CCP1 to CCP2.
Best regards
R.L.
