FUSES HSM and external crystal on 66k80
epalite
PostPosted: Thu Dec 13, 2012 8:48 am     Reply with quote
I am trying to get a 16MHz from an external 4MHz crystal with 4x PLL, however, I seem to be having internal OSC to be driving instead. I read in this forum about the internal OSC will switch over if external didn't get to work.
I put into FUSES the HSM declaration, however, the compiler generated a config word with INTRC_HP XT (see LST below) which I don't think is right.
Anyone can clarify? Thanks!
Source:
#include <18F66K80.h>
#fuses HSM, PLLEN
#use delay(crystal=4M, clock=16M)
LST file:
CCS PCH C Compiler, Version 4.132, 64552               13-Dec-12 22:39
00000:  GOTO   main
.................... #include <18F66K80.h>
.................... //////// Standard Header file for the PIC18F66K80 device ////////////////
.................... #device PIC18F66K80
.................... #list
.................... #fuses HSM, PLLEN
.................... #use delay(crystal=4M, clock=16M)
.................... void main() {
00004:  CLRF   TBLPTRU
00006:  BCF    RCON.IPEN
00008:  CLRF   FSR0H
0000A:  CLRF   FSR0L
0000C:  MOVLB  1
0000E:  CLRF   x88
00010:  MOVLB  F
00012:  MOVF   x5C,W
00014:  ANDLW  80
00016:  MOVWF  x5C
00018:  MOVLW  00
0001A:  MOVWF  x5D
0001C:  BCF    ADCON1.VNCFG
0001E:  BCF    ADCON1.VCFG0
00020:  BCF    ADCON1.VCFG1
00022:  CLRF   x5E
00024:  CLRF   x5F
00026:  BRA    0026
Configuration Fuses:
   Word  1: 511D   VREGSLEEP INTRC_HP SOSC_HIGH NOXINST XT PLLEN FCMEN NOIESO
   Word  2: 3469   NOPUT NOBROWNOUT BORV27 ZPBORM NOWDT WDT8192
   Word  3: 8F00   CANB T0CKB5 T3CKG2 MSSPMSK7 MCLR
   Word  4: 0010   NOSTVREN BBSIZ2K DEBUG
   Word  5: C00F   NOPROTECT NOCPB NOCPD
   Word  6: E00F   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 400F   NOEBTR NOEBTRB
PostPosted: Thu Dec 13, 2012 9:47 am     Reply with quote
Several things.
First XT, is considered the correct mode for a normal 4MHz crystal. HSH, is for crystals over 16MHz, or for the PLL. HSM, for 4M to 16M, with the option of the PLL. Because of your 'crystal' entry in the clock statement, the compiler is overriding the HSM fuse (Duh...). I'd always use ''one or the other', so just put a CLOCK entry in the clock statement, and configure the fuses yourself. If you do this, you will find HSM _is_ selected OK.
Then, these chips _cannot_ start on the crystal. From the data sheet:
"Regardless of which primary oscillator is selected,
INTOSC will always be enabled on device power-up. It
serves as the clock source until the device has loaded
its configuration values from memory. It is at this point
that the FOSCx Configuration bits are read and the
oscillator selection of the operational mode is made."
The internal oscillator is needed for things like the watchdog, so the compiler enables it. However it defaults to enabling high power mode for this oscillator. For lower power, explicitly change this to INTRC_LP if required.
Now, what oscillator is used, once running and the PLL, are controlled by the bits FOSC<3:0>, and PLLCFG. You want 0011 for the former, and '1' for the latter. These are the bottom five bits of Config1H. You want 10011.
If you compile with:
#fuses HSM, PLLEN
#use delay(clock=16M)
And look at these bits:
Word  1: D315   VREGSLEEP INTRC_HP SOSC_DIG NOXINST HSM PLLEN FCMEN IESO
0xD3 = 1101 0011
as required.
The only reason it'd stay running on the internal oscillator in this case, is if the primary doesn't start. If you setup_oscillator, it returns a value, which contains '8' if the primary oscillator is running.
epalite
PostPosted: Thu Dec 13, 2012 11:50 pm     Reply with quote
Thanks!
I found that in order for me to use RC0/1 as IO, I need to add SOSC_DIG to the FUSES statement, otherwise, RC0/1 might be redefined (see data sheet "If a secondary oscillator is not desired and digital I/O on
port pins, RC0 and RC1, is needed, the SOSCSELx
bits must be set to Digital mode.").
Source:
#fuses HSM, PLLEN, CANE, SOSC_DIG
LST:
   Word  1: 5315   VREGSLEEP INTRC_HP SOSC_DIG NOXINST HSM PLLEN FCMEN NOIESO
