problem with pwm
kind2011
problem with pwm
PostPosted: Sun Dec 09, 2012 5:16 pm     Reply with quote
I have a simple code that I expect to generate a pwm with 11khz and 50% duty but isn't, it only works when I change the timer setup for:
setup_timer_2(T2_DIV_BY_16,244,1);
It generates a a 2.77khz wave but when I change for:
 setup_timer_2(T2_DIV_BY_16,68,1);
nothing happens at the ccp1 output?
#include <18F4550.h>
#device adc=10
#fuses HSPLL,WDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN, PUT
#use delay(clock=48000000)
#include <usb_bootloader.h>
#USE FAST_IO (ALL)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int i=0,data;
#int_timer2
void timer2_isr(void)
set_pwm1_duty(data);
void main(){
SET_TRIS_C( 0X00 );
setup_ccp1(CCP_PWM);
clear_interrupt(INT_TIMER2);
PostPosted: Sun Dec 09, 2012 5:24 pm     Reply with quote
Read this thread about pwm with the 18F4550. It might help you:
http://www.ccsinfo.com/forum/viewtopic.php?t=48575
Mike Walne
PostPosted: Sun Dec 09, 2012 5:49 pm     Reply with quote
Is your code supposed to be complete and compilable?
How are you calculating the divisor to get the frequency you expect?
Where does the 'data' value come from to set the duty ratio?
Mike
kind2011
PostPosted: Sun Dec 09, 2012 9:54 pm     Reply with quote
I forgot to set the duty,
this is the complete code and compilable:
#device adc=10
#USE FAST_IO (ALL)
unsigned int16 data;
#int_timer2
void main(){
SET_TRIS_C( 0X00 );
data=511;
With this formula:
The cycle time will be (1/clock)*4*t2div*(period+1)
with a clock of 48Mhz for a cycle time of 92.5us , then period =68
then changing to:
only see a line, not a pwm signal.
Then I noticed that changing period to 200 the duty=60 and period 180 duty=70 then period of 160 and duty=79. From that I think with a period of 68 the duty is 100 but why, if I am not changing the duty?
PostPosted: Sun Dec 09, 2012 10:10 pm     Reply with quote
Read all the pwm links in this post. They will tell you everything you
need to know:
http://www.ccsinfo.com/forum/viewtopic.php?t=45968&start=1
Mike Walne
PostPosted: Mon Dec 10, 2012 1:12 pm     Reply with quote
You're setting the duty to a fixed 10bit 511 value.
When you set the period with:-
1) An 8bit 200 value; the duty ratio is 511/(4*200) = 0,63875 approx 60%
2) An 8bit 180 value; the duty ratio is 511/(4*180) = 0,70972 approx 70%
3) An 8bit 160 value; the duty ratio is 511/(4*160) = 0,79844 approx 80%
You're changing the PWM total period with a fixed ON period, so the DUTY RATIO changes.
Mike
kind2011
PostPosted: Tue Dec 11, 2012 4:16 pm     Reply with quote
Thanks! there's a way to change the period of pwm without changing the
duty ?
Mike Walne
PostPosted: Tue Dec 11, 2012 5:31 pm     Reply with quote
Kindly rephrase this question
there's a way to change the period of pwm without changing the duty ?
As it stands it makes no sense.
You need to clearly understand the basic terms.
The PWM_period is set by
where the 244 is the (PWM_period-1).
The duty_period is set by
where 'data' is the duty_period.
Assuming that 'data' is 16bit, the duty ratio is given by:-
duty_ratio = duty_period / (4 * PWM_period)
So now, what is your question?
Mike
