sahu77
LCD (16*2) to 7-segment conversion |
Posted: Fri Nov 30, 2012 10:49 am |
Need help, requirement for the LCD (16*2) to 7-segment conversion. _________________ sahu |
Posted: Fri Nov 30, 2012 12:46 pm |
We need a lot more information about what you're trying to do.
I 'read 'your post saying that you have a device with a 16x2 LCD and want to transfer what is on that screen to some kind of 7 segement device?
If so, you need to program a PIC to read the data and control pins of the LCD then decode into appropriate command or data then transmit that information to a '7 segment' display. I don't know if there's a commercial 16x2 LED display. Easy enough to design one though and almost any PIC could do the job.
Honestly we need more info from you....the better the feedback from us
hth
jay |
sahu77
Posted: Mon Dec 03, 2012 9:07 am |
temtronic wrote: | We need a lot more information about what you're trying to do.
hth
jay |
I really want three 7 segment display driver CC or CA like 16*2 LCD driver . Due to my bad English, all person may wrongly understand. _________________ sahu |
Mike Walne
Posted: Mon Dec 03, 2012 11:54 am |
What EXACTLY are you trying to do?
Are you trying to REPLACE an LCD with a 7 seg display?
Do you want to ADD a 7 seg display to a board with an LCD?
OR
What?
We can't start to help you 'til you explain.
Why do you want to use a 7 seg display at all?
Can't you use a DLR1414 type display?
Mike |
sahu77
Posted: Mon Dec 03, 2012 7:50 pm |
Mike Walne wrote: | What EXACTLY are you trying to do?
OR
What?
Mike
Need 3pc 7 segment driver (LT543/LT542). HERE display only numeric no. _________________ sahu |
Mike Walne
Posted: Tue Dec 04, 2012 3:37 am |
You're STILL not telling us EXACTLY what you're trying to do.
What is the significance of the LCD?
If you are only displaying 3 digit numbers; why did you not say so at the outset?
Mike
EDIT Is this a re-hash of your March Voltmeter project? |
