waking up from read_adc() + sleep()
oscillot
PostPosted: Fri Dec 06, 2002 2:20 am     Reply with quote
Hey guys,
It says in the data sheet that you can lessen digital noise in the PIC16F877 when utilizing the A/D converter by using the internal A/D clock, enabling int_adc, and using a sleep() command immediately after your read_adc() command...
But perhaps I am misunderstanding something? I tried doing exactly that, and I can't get my program to wake back up, which it is automatically supposed to do I thought? Through test lights, I am pretty sure I get as far as the end of the AD interrupt, but unfortunatley nothing happens after that. Anyone here have any experience with this? Here's what I'm trying to do:
#int_ad
ad_isr(){
disable_interrupts(INT_ADC);
setup_adc_ports(A_ANALOG);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_16);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
enable_interrupts(global);
set_adc_channel(0);
while(true){
enable_interrupts(INT_ADC);
foo=read_adc();
sleep();
(in .h file)
#include <16F877.h>
#device ICD=TRUE
#use delay(clock=38400)
#fuses LP,NOWDT
#use rs232(baud=1200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
Naturally, any and all feedback will be much appreciated. Thanks!
___________________________
Original Post ID: 9815
oscillot
Re: waking up from read_adc() + sleep()
PostPosted: Fri Dec 06, 2002 3:14 am     Reply with quote
hmm, weird. somehow i got it to work. probably because i'm not disabling/reenabling the adc interrupt anymore.
Original Post ID: 9816
R.J.Hamlett
PostPosted: Fri Dec 06, 2002 3:33 am     Reply with quote
:=Hey guys,
:=It says in the data sheet that you can lessen digital noise in the PIC16F877 when utilizing the A/D converter by using the internal A/D clock, enabling int_adc, and using a sleep() command immediately after your read_adc() command...
:=But perhaps I am misunderstanding something? I tried doing exactly that, and I can't get my program to wake back up, which it is automatically supposed to do I thought? Through test lights, I am pretty sure I get as far as the end of the AD interrupt, but unfortunatley nothing happens after that. Anyone here have any experience with this? Here's what I'm trying to do:
:=#int_ad
:=ad_isr(){
:= disable_interrupts(INT_ADC);
:=void main() {
:= setup_adc_ports(A_ANALOG);
:= setup_adc(ADC_CLOCK_INTERNAL);
:= setup_spi(FALSE);
:= setup_psp(PSP_DISABLED);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_16);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_ccp1(CCP_OFF);
:= setup_ccp2(CCP_OFF);
:= enable_interrupts(global);
:= set_adc_channel(0);
:= while(true){
:= enable_interrupts(INT_ADC);
:= foo=read_adc();
:= sleep();
:=(in .h file)
:=#include <16F877.h>
:=#device ICD=TRUE
:=#use delay(clock=38400)
:=#fuses LP,NOWDT
:=#use rs232(baud=1200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
:=Naturally, any and all feedback will be much appreciated. Thanks!
There are two problems here. The first is that the 'read_adc' function, has allready completed the ADC read, before it exits. The second is that the ADC interrupt source has to be enabled to do the wake up, _but_ the global interrupt should normally be disabled. If you look at the 'logic' for the interrupts, all the individual sources are gated by their individual enable bits, and this line then feeds the 'wake up' signal, and goes to the final output gate, where if GIE is set, an actual interrupt will occur. This is not wanted, or the result will be a call to an interrupt handler.
To use the sleep ability, you should enable the ADC interrupt, and disable the global interrupt. Then in your code, define:
#bit ADGO=0x1f.2
#bit ADON=0x1f.0
#bit ADIF=0xC.6
#byte ADRESL=0x9E
#byte ADRESH=0x1E
//Then for your sample.
set_adc_channel(0);
ADON=true;
//Add a slight delay here, or on the first loop, the input
//capacitor will not be fully charged following source
//selection.
delay_us(15);
while(true){
disable_interrupts(GLOBAL);
//Ensure the interrupt flag is clear.
ADIF=false;
//Start the conversion.
ADGO=true;
sleep();
enable_interrupts(GLOBAL)
//Note that these only need to be enabled at all
//if you are intending to use another interrupt.
foo=make16(ADRESH,ADRESL);
You do not need an ISR for the AD interrupt (since none should occur, with the global interrupt disabled). Also unless you are using another interrupt source, you can just leave the global interrupt bit permanently disabled (this is not used by the 'wake up' logic).
Original Post ID: 9817
R.J.Hamlett
PostPosted: Fri Dec 06, 2002 3:35 am     Reply with quote
:=hmm, weird. somehow i got it to work. probably because i'm not disabling/reenabling the adc interrupt anymore.
What will happen in this case, is that the ADC bit will be set, by the read_adc function, and you will fall through the sleep. Your reading will have allready been taken with the chip awake, and you won't get the improved readings you are after...
Original Post ID: 9818
oscillot
PostPosted: Fri Dec 06, 2002 4:59 am     Reply with quote
RJ, thanks so much. you are the man.
Original Post ID: 9823
R.J.Hamlett
PostPosted: Fri Dec 06, 2002 5:32 am     Reply with quote
:=RJ, thanks so much. you are the man.
Thanks.
Good luck with your project
Original Post ID: 9824
oscillot
PostPosted: Fri Dec 06, 2002 6:08 am     Reply with quote
shoot, you know what, now it won't wake up from sleep though. i know this because when i comment it out, my program doesn't hang anymore.
this is stressing me...
Original Post ID: 9825
R.J.Hamlett
PostPosted: Fri Dec 06, 2002 8:20 am     Reply with quote
:=shoot, you know what, now it won't wake up from sleep though. i know this because when i comment it out, my program doesn't hang anymore.
:=this is stressing me...
Post the actual code section now. I have used this in the past, and it worked fine, but I could easily have missed something....
Original Post ID: 9831
oscillot
PostPosted: Fri Dec 06, 2002 8:40 am     Reply with quote
RJ, i want you to know that i really appreciate this. even if you can't find anything.
(from the .h)
#include <16F877.h>
#device ICD=TRUE
#fuses LP,NOWDT
(from the .c)
#int_tbe
tbe_isr(){
// transmit bytes
index++;
putchar(msg[index]);
// if last byte transmitted, stop transmission
if(index==4){
disable_interrupts(INT_TBE);
set_rtcc(0);
setup_spi(FALSE);
set_adc_channel(0);
ADON=true;
delay_us(15);
while(true){
disable_interrupts(INT_RTCC);
output_bit(PIN_E0, 1);
output_bit(PIN_E1, 0);
ADIF=0;
ADGO=1;
sleep();
enable_interrupts(INT_RTCC);
enable_interrupts(INT_TBE);
enable_interrupts(GLOBAL) ;
msg[4]=ADRESH;
msg[3]=ADRESL;
index=3;
putchar(msg[3]);
Original Post ID: 9833
R.J.Hamlett
PostPosted: Fri Dec 06, 2002 9:41 am     Reply with quote
:=RJ, i want you to know that i really appreciate this. even if you can't find anything.
:=(from the .h)
:=#device ICD=TRUE
:=#fuses LP,NOWDT
:=(from the .c)
:=#int_tbe
:=tbe_isr(){
:= // transmit bytes
:= index++;
:= putchar(msg[index]);
:= // if last byte transmitted, stop transmission
:= if(index==4){
:= disable_interrupts(INT_TBE);
:=void main() {
:= set_rtcc(0);
:=set_adc_channel(0);
:=ADON=true;
:=delay_us(15);
:=while(true){
:= disable_interrupts(GLOBAL);
:= disable_interrupts(INT_RTCC);
:= output_bit(PIN_E0, 1);
:= output_bit(PIN_E1, 0);
:= ADIF=0;
:= ADGO=1;
:= sleep();
:= enable_interrupts(INT_RTCC);
:= enable_interrupts(INT_TBE);
:= enable_interrupts(GLOBAL) ;
:= msg[4]=ADRESH;
:= msg[3]=ADRESL;
:= index=3;
:= putchar(msg[3]);
A simple fault!.
The problem is that the bit 'PEIE', has to be enabled for wake-up to work. Whether this is set or not with the code as given depends on the compiler version (the current versions disable this at the same time as the GIE bit), but if you add:
#bit PEIE=0xB.6
And then after enabling the INT_AD, and the global disable, add the line:
PEIE=1;
It should then work.
Note also it should refer to INT_AD, not INT_ADC in the code.
Original Post ID: 9834
oscillot
PostPosted: Mon Dec 09, 2002 5:16 pm     Reply with quote
eureka! it works!
Original Post ID: 9915
R.J.Hamlett
PostPosted: Tue Dec 10, 2002 9:20 am     Reply with quote
:=eureka! it works!
The annoying thing is that that particular problem (the clearing of PEIE by the disable interrupt function), caught me when it first appeared on the CCS compiler (earlier versions only cleared GIE), and I had forgotten it!...
Glad it is sorted now,
Original Post ID: 9935
