Problem with debugging of 18F66J60
stoyanoff
PostPosted: Thu Nov 08, 2012 3:26 am     Reply with quote
Hi! I made a program for 18F66J60. It combines TCPIP stack and MDD card stack. The program compiles but when I run it it blocks.
When I stop the debugger(PicKit 3) it points to
#use delay(clock=25 000 000)
Here is the code before this row:
  #include <18f66j60.h>
   #fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
   #define PIN_LED1  PIN_B5
   #define PIN_LED2  PIN_B4
   #define PIN_LED3  PIN_B3
   #define LED_ON(x)    output_low(x)
   #define LED_OFF(x)   output_high(x)
  #define BUTTON_PRESSED()   !input(PIN_A4)
  #include "filesystem\p18cxxx.h"  //C18 to PCH compatability
  #use delay(clock=25000000)
Can you tell me what`s causing that???
Thanks!
rodrigo.bzsilva
Re: Problem with debugging of 18F66J60
PostPosted: Tue Nov 20, 2012 6:13 am     Reply with quote
Thanks!
try to use the directive #use delay before the defines.. soon after the #fuses..
