SPI interrupt doesn't work after breakpoint
ralpok
PostPosted: Mon Nov 12, 2012 11:45 am     Reply with quote
I am utilizing a PIC24FV32KA304 devices and PCWHD 4.134 on Win 7. I have recently added an SPI slave peripheral to my source and running the transactions for this peripheral off of interrupts driven by the master. If I start my application and let it run, the SPI interrupts work flawlessly. If I ever halt the code, or hit a breakpoint, after this event the SPI interrupt never fires again. It doesn't matter if the breakpoint is in the mainline of the source or the interrupt. I can't seem to be able to figure out what I have done to disable this interrupt. Any ideas? It is significantly impeding my ability to debug my source code.
PostPosted: Mon Nov 12, 2012 12:08 pm     Reply with quote
Several, but without seeing your source code, there is no way to decide what is wrong !
You should submit a small, compilable program that gives the 'error' so others can try it and decide where the problem is.
Get rid of everything that is NOT needed to show the problem.
hth
jay
PostPosted: Tue Nov 13, 2012 5:33 am     Reply with quote
It sounds a bit like you have problems with SPI receive buffer overflow during the breakpoint, but I can't find this quick how that affects the hardware SPI. For example the UART will block on receive buffer overflow but I can't find a description for the SPI buffer in this situation.
The PIC24FV32KA304 has many more SPI options than the PIC18 series. For example there are 8 different settings for when a SPI interrupt should be generated. Also, are you using the 'Standard buffer mode' with one buffer, or the 'Enhanced Buffer Mode' with 8 FIFO buffers?
Without any more info on how your SPI is configured it is impossible to say where your code is at error.
FvM
PostPosted: Tue Nov 13, 2012 9:55 am     Reply with quote
I also expect an overflow condition. You can see it in the SPI status.
