adammenzies
CCP_PWM_HALF_BRIDGE mode on PIC16F1933 |
Posted: Wed Nov 07, 2012 11:36 am |
Hi All,
I am trying to setup a half bridge driver using a PIC16F1933.
According to the datasheet (page 198) I should see this (ignore dead-band for now):
P1A: ____|--|___
P1B: |--|_____|--|___
But what I'm actually seeing is:
P1A: ___|--|___
P1B: ----|__|----
(i.e. P1B = !P1A)
Here is my code:
Code: | #include "16F1933.h"
/* setup fuses */
#fuses HS,NOWDT,BROWNOUT,PUT
#use delay (clock=20000000)
// setup all of B and C as outputs (need to change later)
set_tris_b(0x00); // Set pins B as outputs
set_tris_c(0x00); // Set pins C as outputs
// Setup the ECCP for PWM in half bridge mode.
setup_ccp1(CCP_PWM_HALF_BRIDGE | CCP_PWM_H_H, 25);
// setup timer 2 for 25kHz
setup_timer_2(T2_DIV_BY_4, 200, 1);
set_pwm1_duty(75);
Any thoughts? |
Posted: Wed Nov 07, 2012 1:01 pm |
set_pwm1_duty(75L);
Search the forum, or read the manual for 'why'.
adammenzies
Posted: Wed Nov 07, 2012 1:42 pm |
Hi Ttelmah,
Ttelmah wrote: | set_pwm1_duty(75L); |
I appreciate the syntax correction, but that still didn't resolve the issue. I'm still getting P1A=!P1B instead of what's described on page 198 of the datasheet.
Here's a scope trace since ASCII art is not my forte!
Posted: Wed Nov 07, 2012 1:54 pm |
Neither your text version or your picture show P1A=P1B. P1B is off when P1A is ON, less the deadband times.
adammenzies
Posted: Wed Nov 07, 2012 1:59 pm |
Ttelmah wrote: | Neither your text version or your picture show P1A=P1B. P1B is off when P1A is ON, less the deadband times.
I agree it's not P1A=P1B, but if you look at the original post I suggested P1A=!P1B. (i.e. P1B is the inverse of P1A)
This is not what's on the datasheet. |
Posted: Wed Nov 07, 2012 2:59 pm |
Quote: | According to the datasheet (page 198)
Post the Figure number and the title of the Figure in the data sheet.
That's needed because datasheets have different revisions and the
page numbers change on each one. |
adammenzies
Posted: Wed Nov 07, 2012 3:04 pm |
Quote: | Post the Figure number and the title of the Figure in the data sheet. |
It's Figure 19-6 EXAMPLE PWM (ENHANCED MODE) OUTPUT RELATIONSHIPS (ACTIVE-HIGH STATE)
The second set of plots (Half-Bridge) shows P1A and P1B with equal pulse width, 90 degrees out of phase. |
Posted: Wed Nov 07, 2012 3:28 pm |
So basically your entire complaint is that you don't have 50% duty cycle.
Go to this page and read all the threads on 10-bit PWM mode.
http://www.ccsinfo.com/forum/viewtopic.php?t=45968&start=1
After you have done that, you will understand how to set your duty cycle
value to give you 50% duty cycle. |
adammenzies
Posted: Wed Nov 07, 2012 4:44 pm |
PCM programmer wrote: | So basically your entire complaint is that you don't have 50% duty cycle. |
Possibly I'm not describing my issue very well. I can get 50% duty cycle no problem, and in fact it is the one exceptional value which produces the result I'm looking for.
Let's take any value less than 50%; for the sake of this discussion I'll use 33%, and for simplicity I'll assume no deadtime.
According to the datasheet, if I setup in half-bridge mode with a 33% duty cycle, I should see this:
(33% duty cycle on each channel)
But I actually see this:
(33% duty cycle on P1A, 66% duty cycle on P1B)
Am I reading the datasheet wrong? |
Posted: Wed Nov 07, 2012 5:16 pm |
Now it looks like your problem is that you don't have any deadband time
specified. Add the following routine above main(). Then call it after you
call setup_ccp1(). Put in some number for the deadband, such as 64.
Then look at the waveforms on your oscilloscope:
// Call this routine to set the PWM deadband.
// The deadband value can be from 0 to 127,
// and is in units of Instruction Cycles (Fosc/4).
// For example, with a 4 MHz crystal, an instruction
// cycle is 1 us.
void set_deadband(int8 deadband)
#byte PWM1CON = getenv("SFR:PWM1CON")
if(deadband > 127) // Do a limit check on the value.
deadband == 127;
PWM1CON = deadband;
Example of how to use the function:
