Increment count on LCD display?
hemnath
PostPosted: Mon Nov 05, 2012 10:28 pm     Reply with quote
I want to increment a count and display in lcd, when pushbutton is pressed. Button connected to PIN C0. It compiles successfully. In the display it shows count, but when i press push button it shows different characters at location 0x86 in the display. Please help...
#include "18F2520.h"
#fuses  INTRC_IO
#use delay(clock=4000000)     // internal clock
#define RS PIN_A2
#define EN PIN_A1
void lcd_init();
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
unsigned char data[] = "count";
unsigned int i = 0;
unsigned int counter = 0;
int16 temp;
lcd_init();
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
   while(data[i]!='\0')
      lcd_data(data[i]);
      i++;
   lcd_cmd(0x86);
   if(input(PIN_C0)==0)
      delay_ms(200);
      temp=counter++;
      lcd_data(temp);
void lcd_init()
lcd_cmd(0x30);      // Configure the LCD in 8-bit mode, 1 line and 5x7 font
lcd_cmd(0x0C);      // Display On and Cursor Off
lcd_cmd(0x01);      // Clear display screen
lcd_cmd(0x06);      // Increment cursor
lcd_cmd(0x80);      // Set cursor position to 1st line, 1st column
void lcd_cmd(unsigned char c)
output_b(c);
output_low(RS);
output_high(EN);
delay_ms(15);
output_low(EN);
void lcd_data(unsigned char z)
output_b(z);
output_high(RS);
output_high(EN);
delay_ms(15);
output_low(EN);
Mike Walne
PostPosted: Tue Nov 06, 2012 2:36 am     Reply with quote
Please explain what you are expecting to see on the display with what you actually get.
Maybe you're confusing ASCII char with numeric value.
Mike
PostPosted: Tue Nov 06, 2012 3:35 am     Reply with quote
As Mike already suggested, the value you are sending to the display is a binary value. What you see on the LCD is the corresponding ASCII value and this won't make sense to us humans.
You need to convert the binary data to readable text first, for example using the function itoa() or sprintf("%d").
CCS has implemented a very useful extension to the printf function where you can redirect the output to another function that will display the data. This output function should have a single character as parameter, just like your lcd_data function so that makes it very easy.
Replace
lcd_data(temp);
by:
printf(lcd_data, "%d", temp);
Note that you can make your program a lot simpler when you add your text 'count' to the above line, but I leave that as an exercise to you.
Kumara
PostPosted: Tue Oct 22, 2013 4:05 am     Reply with quote
Mike
Hi, Please refer following code for incensement counter with debouncing solution.
Kumara
#include <16F877A.h>              // Pic Microcontroller (MCU) Select
#DEVICE ADC=10                    // 8 Bit analog resolution
#fuses NOWDT,HS, NOPUT, NOPROTECT // Fuses
#fuses NOBROWNOUT, NOLVP          // Fuses
#use delay(clock=20000000)        // Crystal Oscillator Frequency ( 20 MHZ)
#include <lcd.c>                  // Driver for LCD Module
   void main()                    // Main block
   INT16 PRE_COUNT=0;               // Declare variable)
   INT16 SET_COUNT;                 // Declare variable
   INT1 SW1;                      // Declare variable
   BOOLEAN ISPRESSED=FALSE;       // Boolean logic=0;
   setup_adc_ports(AN0);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   lcd_init();
   while (TRUE) {                // Endless loop
   SW1=INPUT(PIN_C0);            // Positive inputs
         IF(PRE_COUNT==0)
         lcd_putc("\f");         // LCD clear
         lcd_gotoxy(1,1);        // Select Raw 1 & start digit 1 position
         printf(lcd_putc," PRE_COUNT:%04LU ",PRE_COUNT);
         lcd_gotoxy(1,2);        // Select Raw 2 & start digit 1 position
         printf(lcd_putc," SET_COUNT:%04LU ",SET_COUNT);
         DELAY_MS(200);
         SET_ADC_CHANNEL(0);     // INPUT AN0
         DELAY_US(100);
         SET_COUNT=READ_ADC();   // SET VALUE= RA1 ( 10K V/R )
         SET_COUNT=(SET_COUNT);  // FOR 4 DIGITS UP TO 1023
         IF (SW1 && !ISPRESSED)  // This line must be here
         DELAY_MS(10);           // This line must be here
         SW1=INPUT(PIN_A1);      // This line must be here
         IF(SW1)                 // This line must be here
         {PRE_COUNT++;           // This line must be here
         ISPRESSED=TRUE;         // This line must be here
         DELAY_MS(100);
         IF(PRE_COUNT>=SET_COUNT) // This line must be here
            OUTPUT_HIGH(PIN_B0);
         ELSE
            OUTPUT_LOW(PIN_B0);
         IF(!SW1)                 // This line must be here
         ISPRESSED=FALSE;         // This line must be here
