Problems using dspic33ep256mu806 AN0 and AN1 ADC
mizzard
PostPosted: Mon Nov 05, 2012 5:19 am     Reply with quote
Hello everybody, I am going to explain my problem.
I am developing a prototype using dsPIC33EP256MU806, in wich I need to use the 2 analog inputs, AN0 -> RB0 and AN1 -> RB1
I use PCWHD compiler from CCS version 4.128
The problem is that I can not read the correct ADC value (tested using a voltimeter and can see the desired voltage) either in AN0 and AN1.
The dsPIC is working because I use 4 hardware USARTs and I can see debug lines using fprintf.
I attach my first code:
Main.c
void main(){
  unsigned int16 lectura = 0;
  setup_adc_ports(sAN0 | sAN1 | VSS_VDD);
   set_adc_channel(0);
   delay_us(READ_SAMPLE_TIMES);
   delay_ms(3000);
   fprintf(DEBUG,"Arranco\r\n");
   while(true){
      lectura = read_adc(ADC_START_AND_READ);
      fprintf(DEBUG,"ADC: %lu",lectura);
And the second one:
Main.c
void main(){
ADON = 0;      // ADC off
   AD12B = 0;     // 10 Bits
   FORM_1 = 0;    // unsigned int
   FORM_0 = 0;
   VCFG_2 = 0;    // AVdd - AVss
   VCFG_1 = 0;
   VCFG_0 = 0;
   CHPS_1 = 0;    // converts ch0
   CHPS_0 = 0;
   ADRC =1;       // Internal clock RC ADC
   SAMC_4 = 0;    // 0Tad
   SAMC_3 = 0;
   SAMC_2 = 0;
   SAMC_1 = 0;
   SAMC_0 = 0;
   CH0SA_4 = 0;   // AN0
   CH0SA_3 = 0;
   CH0SA_2 = 0;
   CH0SA_1 = 0;
   CH0SA_0 = 0;
   ADON = 1;      // ADC ON
delay_ms(3000);
   while(true){
Main.h
// ADC CONFIG
#WORD AD1CON1 = 0x0320         // ADON(15) - AD12B(10) - FORM(9,8)
#BIT ADON = AD1CON1.15
#BIT AD12B = AD1CON1.10
#BIT FORM_1 = AD1CON1.9
#BIT FORM_0 = AD1CON1.8
#WORD AD1CON2 = 0x0322         // VCFG(15,14,13) - CHPS(9,8)
#BIT VCFG_2 = AD1CON2.15
#BIT VCFG_1 = AD1CON2.14
#BIT VCFG_0 = AD1CON2.13
#BIT CHPS_1 = AD1CON2.9
#BIT CHPS_0 = AD1CON2.8
#WORD AD1CON3 = 0x0324         // ADRC(15) - SAMC(12,11,10,9,8)
#BIT ADRC = AD1CON3.15
#BIT SAMC_4 = AD1CON3.12
#BIT SAMC_3 = AD1CON3.11
#BIT SAMC_2 = AD1CON3.10
#BIT SAMC_1 = AD1CON3.9
#BIT SAMC_0 = AD1CON3.8
#WORD AD1CHS0 = 0x0328         // CH0SA(4,3,2,1,0)
#BIT CH0SA_4 = AD1CHS0.4
#BIT CH0SA_3 = AD1CHS0.3
#BIT CH0SA_2 = AD1CHS0.2
#BIT CH0SA_1 = AD1CHS0.1
#BIT CH0SA_0 = AD1CHS0.0
In both cases I always see 512 value.
I have simplified the code, so there is some configurations that I have omitted
Do you have any idea how to solve this problem?
Any suggestion will be appreciated, thank you so much.
PostPosted: Mon Nov 05, 2012 7:23 am     Reply with quote
Obvious first thing, you have got Avdd, and AVss connected?. The supply for the ADC, is separate on these chips.
mizzard
PostPosted: Mon Nov 05, 2012 8:15 am     Reply with quote
Yes, tested with multimeter. I have 3.3V on AVdd pin (number 19) and GND on pin number 20.
Another thing I have detected is when I use set_adc_channel(0) occurs that I have said, but when I use set_adc_channel(1), the dsPIC is continiously on reset.
I have checked an0, an1, Avss, and AVdd lines and I don't find any problem. Confused
PostPosted: Mon Nov 05, 2012 9:39 am     Reply with quote
Wondering if fuse setup is not right, and it thinks these pins are to be used for ICD/programming. However if you can program the chip this doesn't make sense.
mizzard
PostPosted: Mon Nov 05, 2012 9:44 am     Reply with quote
Here are my fuses:
#include <33EP256MU806.h>
#device adc=10
#FUSES PUT128                   //Power On Reset Timer value 128ms
#FUSES PR_PLL
#FUSES HS
#FUSES ICSP1
#FUSES OSCIO
#FUSES CKSFSM
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
