Simone
Float number problems |
Posted: Sat Nov 03, 2012 3:20 am |
I'm using CCS PCD C Compiler for PIC24EP512GU810.
I've a problem with float number operations. Here an example inside a function:
float vAOUT1 = -8.3
float p = 10.0F - vAOUT1;
if (p < 0.0F) // p is 1.7, but it return FALSE
return(FALSE);
Can someone help me? |
Posted: Sat Nov 03, 2012 3:42 am |
Critical question is always 'compiler version'....
Do a search on the forum, for 'PCD float', and select to include all terms.
If you must do a float comparison, use float48, which seems to be more reliable than the default.
Mike Walne
Posted: Sat Nov 03, 2012 3:45 am |
p is NOT 1.7
If vAOUT1 is -8.3 then
10 - vAOUT1 becomes
10 - -8.3 = 18.3
Can't help with the rest.
Mike |
FvM
Posted: Sat Nov 03, 2012 4:12 am |
The code is working correctly with recent PCD versions (skipping return FALSE), tested with V4.127 and 4.135. |
Posted: Sat Nov 03, 2012 5:23 am |
Yes, to Mike, I too had spotted the error in the number involved, but the result should still be false.
Yes, on versions. It was a sequence around the early 4.1xx area, where oddities appeared with this type of test, was fixed, then appeared again, over a number of compilers. Hence the critical 'what version' question.
Had some code that had to be 'bodged' to work correctly round then, and it seems to be fine for the last few compiler versions, so agree it does not now apply.
