18f2431 PLL
rikotech8
18f2431 PLL
PostPosted: Thu Nov 01, 2012 11:01 am     Reply with quote
I'm using PIC18F2431 and the compiler version: 4.114
I am using 10MHz crystal resonator and my wish is to use PLL function to made 40MHz clock via multiplying oscillator frequency by 4. The problem is that I can't see neither oscillator settings for PLL, nor PLL fuse in my header file. How to set PLL on my clock?
PostPosted: Thu Nov 01, 2012 11:45 am     Reply with quote
H4
rikotech8
what do you mean H4
PostPosted: Fri Nov 02, 2012 9:49 am     Reply with quote
PostPosted: Fri Nov 02, 2012 10:13 am     Reply with quote
The fuse to activate the PLL, is "H4". Stands for HS with *4 PLL. The fuse names on your compiler predate CCS 'standardising' on HS_PLL for this.
rikotech8
PostPosted: Fri Nov 02, 2012 12:01 pm     Reply with quote
oh I see now.
Thank you Ttelmah!
