Passing array
m_embedded
Passing array
PostPosted: Wed Oct 31, 2012 12:06 am     Reply with quote
I'm facing a spurious result while passing array to the functions.
For example, to compare two strings
char str1[6]="hello";
char str2[6]="hello";
if(strcmp(str1,str2)== 0)
  match found
  mismatch
If I use the above statement I'm not getting the correct output, however if I change the statement like this
if(strcmp(&str1[0],&str2[0]) == 0)
  match found
  mismatch
then I would able to get the correct answer. What will be the problem ?
PostPosted: Wed Oct 31, 2012 2:06 am     Reply with quote
Tell us the critical thing. _Compiler version_.
There was an oddity reported here a few weeks before with the handling of arrays and pointers on 4.134, and it could be this re-appearing in a different form...
m_embedded
PostPosted: Wed Oct 31, 2012 2:26 am     Reply with quote
my version is
ccs
IDE VERSION 4.127
PCB VERSION 4.127
PCM VERSION 4.127
PCH VERSION 4.129
PCD VERSION 4.127
and I'm using pic18f2620.
PostPosted: Thu Nov 01, 2012 12:42 am     Reply with quote
I tested the program shown below with vs. 4.127 and vs. 4.129 and it
works every time for me. It always shows match found. This was
tested in MPLAB simulator.
match found
match found
match found
match found
match found
#include <18F2620.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
#include <string.h>
if(strcmp(str1,str2) == 0)
  printf("match found \r");
  printf("mismatch \r");
printf("\r");
m_embedded
PostPosted: Thu Nov 01, 2012 12:56 am     Reply with quote
match found
match found
match found
match found
match found
#include <string.h>
printf("\r");
For me also its working with simulator, but when tested with the hardware I'm not getting the expected result. Thats why I have posted this question. What may be wrong in this case ?
PostPosted: Thu Nov 01, 2012 1:56 am     Reply with quote
I took the time late last night to stick it into a 2620, and test it for real. Runs fine for me, compiled with 4.118, 4.127 and 4.134.
I'm wondering if there is a problem with your install. The file containing the chip details, is 'devices.dat', and this is version specific. I don't remember ever seeing a download that gives a different .pch version from the .pcm version, and since they share this file, wonder at seeing .pch at .129, with the other files all at .127.....
m_embedded
PostPosted: Thu Nov 01, 2012 5:30 am     Reply with quote
this thing is very strange , i have tried with different controller pic18f46k22 also , still the same problem exists , so i will uninstall every thing and install it again and going to try and see .. Thank you for your efforts ..
