PIC18F452 @ 20MHz slowdown by LED.
Rob_975
PostPosted: Tue Oct 30, 2012 2:34 pm     Reply with quote
I have a PIC18F452 with 20MHz crystal behaving strange.
When I insert the lines :
output_low(PIN_D7);
delay_ms(1500);
output_high(PIN_D7);
The PIC seems to be slow and the text on the LCD display is changing slowly (like when a LCD is working at low temperature). The LED is blinking OK.
When those lines are greyed out, everything is fine, and the display is reactive.
Compiler 4.120
Cheers.
Mike Walne
PostPosted: Tue Oct 30, 2012 2:40 pm     Reply with quote
You're adding a 1.6 second delay into your system.
Why are you surprised that everything seems to be so tardy?
Mike
PostPosted: Tue Oct 30, 2012 2:42 pm     Reply with quote
Every delay_ms(xxx),delay_us(xxx),etc. the PIC will 'twiddle it's thumbs' and do NOTHING except loop around and around, counting down until the total time expires for the 'delay'.
NOTHING else can happen until the PIC exits the delay routine...
If you printout the listing and read the delay_aa(xxx) code, you'll see why.
If you want the PIC to do anything else while a 'delay' is in progress, you need to run timers and interrupts to achieve 'multitasking'.
hth
jay
