Half bridge PWM [solved]
Yasin
PostPosted: Fri Oct 26, 2012 11:23 pm     Reply with quote
Dears,
Kindly help in generating a half bridge PWM in CCS C Complier v4.084 for PIC16F690 for using in a buck converter. I have used the following code it is not working.
#include "C:\Program Files\PICC\Devices\16F690.h"
#DEVICE   ADC=10,*=16
#fuses INTRC_IO,NOWDT,NOPROTECT,NOBROWNOUT,PUT,FCMEN,NOCPD,NOIESO
#use delay(clock=8000000)
#define   BUCK_CTRL_PWM      PIN_C5         //PWM Pins SPV & MCA charge pins as PWM and other two as GPIO
#define   BUCK_FB_PWM      PIN_C4
#define   AUX_SUP_PWM      PIN_C3
#define   PWM_A_Channel      1      //Buck control PWM1         // for disable and enable program
#define   PWM_B_Channel      2      //Buck control PWM2
#define   PWM_C_Channel      3      //Auxillary power supply PWM
#define PWM_AB_Channels      4
#define PWM_All_Channels   5      //Disable all
void Init_controller(void)
   setup_oscillator(OSC_8MHZ);
   set_tris_a(0xdf);                                 //Configure PORTA
   set_tris_b(0x7f);                                 //Configure PORTB
   set_tris_c(0xc7);                                 //Configure PORTC
   Disable_pwms(PWM_All_Channels);
   Init_pwm();
void Init_timer1(void)
void Init_pwm(void)
   setup_timer_2(T2_DIV_BY_1,200,1);                     //TIMER2 PRESCALER=16; Built in function
   setup_ccp1(CCP_PWM, CCP_PWM_HALF_BRIDGE | CCP_PWM_H_H );
    set_deadband(10);
   set_pwm1_duty(0);
void set_deadband(int deadband)
   #byte PWM1CON = 0x9B
   if(deadband > 127)
      deadband == 127;
   PWM1CON = deadband;
void Disable_pwms(unsigned char j)
   channel = j;
   switch(channel)
      case 1:   input(BUCK_CTRL_PWM);
      case 2:   input(BUCK_FB_PWM);
      case 3:   input(AUX_SUP_PWM);
      case 4:   input(BUCK_CTRL_PWM);
            input(BUCK_FB_PWM);
      case 5:   input(BUCK_CTRL_PWM);
            input(BUCK_FB_PWM);
            input(AUX_SUP_PWM);
      default:   break;
void Enable_pwms(unsigned char j)
   channel = j;
   switch(channel)
      case 1:   output_low(BUCK_CTRL_PWM);
      case 2:   output_low(BUCK_FB_PWM);
      case 3:   output_low(AUX_SUP_PWM);
      case 4:   output_low(BUCK_CTRL_PWM);
      case 5:   output_low(BUCK_CTRL_PWM);
      default:   break;
   Init_controller();
   while(!OSC_STATE_STABLE)
   Enable_pwms(PWM_AB_Channels);
       set_deadband(10);
      set_pwm1_duty(50);
Pls help to find my error or pls provide a half bridge pwm working code.
It is very urgent.
Yasin
HB PWM working but dead time not working
PostPosted: Sat Oct 27, 2012 12:24 am     Reply with quote
the pwm is now working ok. when I change
setup_ccp1(CCP_PWM, CCP_PWM_HALF_BRIDGE | CCP_PWM_H_L);
to
setup_ccp1(CCP_PWM_HALF_BRIDGE | CCP_PWM_H_H);
the half bridge pwm is working.
But still the dead time is not working.
Pls help for dead time generation in PIC16F690.
Yasin
PostPosted: Sat Oct 27, 2012 12:38 am     Reply with quote
Thanks to the following post both half bridge and dead time is working fine.
http://www.ccsinfo.com/forum/viewtopic.php?p=156440
Thanks every body.
magnoedu
y trying the same project
PostPosted: Tue Jul 28, 2015 9:09 pm     Reply with quote
I am trying the same project, but this code don't compile, he is make lot of errors with define.
Anyone help me.
PostPosted: Wed Jul 29, 2015 5:25 am     Reply with quote
You are correct. The code he posted will not compile/work for many
reasons. What they are actually using is definitely not this code as written..
The link he references may help
